Results 1 to 10 of 17
    Apr 2006
    TAXACHUSSETTS
    1,509
    Default 84' of pipe railing
    Recent job i fabbed and installed.questions comments fire away.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    258
    admweld,
    Looks good. Do you bid this by the foot or do T&M? Right now for steel structure fab we are $1.75 per lb, $2.50 per lb painted.
    Apr 2006
    TAXACHUSSETTS
    1,509
    Bid it/quoted, No paint no primer.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Edmonton,Alberta.
    632
    Hard to tell from the pics but how did you prep the brick for receiving the posts?
    Apr 2006
    TAXACHUSSETTS
    1,509
    Quote Originally Posted by Cornerstone View Post
    Core drilled a 2-1/2"hole with a Hilti/Te76 hammer drill.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Feb 2006
    Northern CA, Shasta CO.
    157
    Looks pretty good. Nice job. Next they need to get some stops in place before somebody knocks it all down. Brick and all.
    Noob question .......was it mig or stick
    Apr 2006
    TAXACHUSSETTS
    1,509
    Quote Originally Posted by nrhmarine7 View Post
    Migged in the shop fabbing/Stick on the install for the field connections/joints.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    Quote Originally Posted by admweld View Post
    How come you switched?
    Apr 2006
    TAXACHUSSETTS
    1,509
    Because i,m not going to lug a bottle out of my shop to mig weld the joints when i can do it just as easily with 6011 stick.There where only a couple of connections also.If had 400' of railing to install i may switch to my spoolgun and a bottle and start migging but this was a small job not worth it.Also any wind in the field and your mig welding is going to look like crap.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
