Results 1 to 10 of 10
Thread: Shop equipment
    Default Shop equipment
    What would be the least ammount of equipment a small shop could thrive.
    Make your wish list.
    Equipment
    The simplest Welding-shop equipment that permits you to perform your work is probably all that you need for getting started. For work on low carbon steel an example would be a simple AC transformer welding power supply. Keep in mind that used and reconditioned equipment may be available at substantial savings.
    Fancy looking machines with all sort of additional capabilities may be strongly promoted by suppliers, but the question is if they are going to help your business become more productive and successful. New equipment should be first rented or leased for a short while, to decide if it actually provides benefits.
    Besides electric welding equipment, an oxyacetylene welding kit mounted on a hand cart holding two gas cylinders is almost a must for any Welding-shop and maintenance facility. An air compressor may be needed to power pneumatic tools.
    Apart from welders you will need accessories, like disc cutters, grinders, welding table with a sturdy vise, files, hammers to remove slag etc. and of course personal protection devices like welding mask, goggles, gloves, apron and so on. See
    www.welding-advisers.com/Welding-shop.html
    Lake of the Ozarks MO
    3,446
    I am confused......did you just post a question and then answer yourself???
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Cave Creek Az
    796
    The least??? a welder.
    I would think you would need a welder, chop saw, 4 1/2" angle grinder, assorted hand tools (hammer, chisels, wrenches, ratches, sockets, etc), gloves, hood, soapstone, tape measure. That would be a bare minimum to do rudimentary work. I would then add an O/A setup, then air compressor (and air tools), then plasma cutter, then big steel fab table, bench grinder, 'nother welder (need a stick and a mig). There you have a basic shop, then you can shop for the big guns, ironworker, CAD plasma cutter, mill, lathe, sheet metal tools (brake, shear, bead roller, sliproll, etc)
    I am somewhere betwixt the two at the moment, and can do most anything, some things just take longer.
    Vancouver BC Canada
    605
    Uh.... that seems to be the case. move over, give me a little seat space on the bench.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    So. Cal
    335
    Default Ad Spam...!...??
    I think this is ad spam. Check the link at the bottom of his post....
    TacMig
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    Well I just needed some advise and found the article of startup equipment anyone could ad suggestions. I put the link of the article I found but meant no spam. Just need some advice.
    Thanks anyway
    gate city virgina
    213
    and for big jobs with a whole lot of grinding i would add a 71/2 inch angle grinder, i got one real cheap at a tent sale for 25 bucks
    So. Cal
    335
    Default Welcome...
    Quote Originally Posted by El Guanche View Post
    Thanks anyway
    Didn't mean to offend you! It's that we have had spam here before and your original post along with your reply looked a little odd. In any event, good luck and happy welding.
    TacMig
    We depend On:
    Anderson & Co. LLC
    Metal Cr
    afters
    3
    a good chop saw is a necessity. A grinder- you can get by with a 4 1/2" grinder but make sure you get a good one because if not you will replace them on a regular basis. torch setup.
