Results 1 to 2 of 2
    Default thin to thick tig welding
    I'm new to the whole tig thing but need to get up to speed on welding thin (22 guage) to thicker (3/16") 304 stainless steel. Any help is appreciated.
    Vancouver BC Canada
    605
    yeah i hear ya. I was trying to fuse a 3/8 Al rod to some 1/8th plate and it kept blowing out. I iether melted the rod into goo or the plate went all wrinkly..need practice.
    Propulsion, syncroman, engloid and alot of other fellows here are good choices for brain picking. Theres alot of experience years on this forum and the motorsports side.
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
