just keep in mind even if youdo use 8 or 10 gage for your part of the new wireing, the part in the wall is still only 12 gage at best and possibly 14 depending on the circuit and the building ages who knows what might be in the wall. best thing to do would be get a maxsyar or dyn and run it of 120V at the dryer outlet as its likely to be the only thing on it and a 20 amp circuit. although it too could be almost anythingone would hope it to be the best option. those welders were made for this situation. take advantage of it.
Results 71 to 80 of 113
12-17-2007, 02:38 PM #71
james@newyorkmetalart.com
12-17-2007, 04:06 PM #72
12-17-2007, 04:37 PM #73
- Jun 2006
- Killingworth,Ct.
- 372
12-17-2007, 04:40 PM #74
- Jun 2006
- Killingworth,Ct.
- 372
12-17-2007, 04:56 PM #75
- Nov 2007
- New Brunswick, Canada
- 38
"I need advice as to what CAN be done and what is too unsafe or impossible".
Tempriser,
If you haven't seen enough by now to answer your initial question, pls tell me you live in a single family dwelling and you are not going to put other peoples lives in your building in danger by doing this.
12-17-2007, 04:58 PM #76
Without having 240, the little outlet adapter thing won't work. No two ways about it.
I also wired all of my double gang outlets on double legs so as to have 20A 240 available at every existing single phase outlet in the shop with the exception of an outlet mounted high on the wall for the stereo.
Since most of these circuits are on GFI's I'll need to replace those in the event I need to utilize this design, but that's all there is to it.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
12-17-2007, 05:33 PM #77
- Sep 2006
- Abilene, Texas
- 639
Here's my take on this. Yep, you can combine 2 110 outlets for 220 if they are on different legs in the box. Would I do this he!! no. Let me go back to Tempraiser's first post. Would you be up to your knees in danger? I think so. I addressed your question but it doesn't matter since I'm not a mod here.
Tempraiser, are you a lawyer, aka Joe Buffalo?? If not, you should be!! You and he share so many qualities. He has the honor of being the one person on my ignore list.Jim
12-17-2007, 08:36 PM #78
The more I read . . .
The more I read this thread I have to think . . . What does Tempriser really want, an answer . . . No I don't think so, this is merely a form of entertainment for an egghead engineer . . . .
Tempriser, this board is full of people who love to weld...some are pros, some are hobbiest from all walks of life . . . we all have friends, neighbors & co-workers to turn to for info on ANYTHING . . . .
Why is it so hard for you to accept that what you want to do is unsafe...
You do not tell us what your background is, ie . . profession or education.
Nor do you tell us your location . . . .
I THINK YOU ARE A TROLL ! ! ! !
Millermatic 251
Lincoln AC/DC "Tombstone"
Milwaulkee Grinder 4 1/2"
Clark Grinder 4 1/2"
12-17-2007, 08:42 PM #79
- Dec 2007
- 19
I haven't said anything for a while. I really want to know if anyone has more experience with paralleling. I talked to the Miller guys and they didn't have a whole lot of information. Has anyone modified a pedal to control two tigs?
12-17-2007, 08:44 PM #80
Do I Dare?!?!?
I was thinking about paralleling my wiener... A swift hack with the ol' axe and I might be able to pee into two seperate urinals.....from 10 feet away....
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
