Page 6 of 12 FirstFirst 1234567891011 ... LastLast
Results 51 to 60 of 113
  1. #51
    Nov 2007
    Ontario, Canada
    72
    Quote Originally Posted by tempraiser View Post
    You can parallel machines? You mean if I bought two Maxstar 150 STH/STL inverters and hooked their outputs together, I could double the output? I would think there would be problems with that.
    Yes you can parallel machines. Not cost effective though, unless you already have two machines.
    XMT-300 with S-64 wire feeder.
    Lincoln HI-FREQ modified to run XMT.
    Esab PCM-875 plasma cutter.
    Miller Spoolmatic-1
    Miller PC-300 pulser
    Miller Optima pulser
  2. #52
    Nov 2007
    Ontario, Canada
    72
    Isn't it usually advantageous to use two different phases in your house to balance loads? I would imagine that with luck and a long (and thick) enough extension cord, I should be able to find opposite phases. Making my own from eight-gauge wire might solve distance problems.
    8ga is overkill. 12 or 10 would be plenty.
    Miller Spoolmatic-1
  3. #53
    19
    That's basically what I was planning to do, but I wanted a little more security. I was going to wire a microchip with a comparator, two 30A relays, parts of two of these http://www.professionalequipment.com...qx/default.htm
    (I need to test if the hot and neutral wiring is reversed and don't want to pull out a multimeter every time), and a few LEDs to indicate opposite phase availability. With a small transformer, a rectifier, a cap, and a comparator, I could test to see if the difference between the two hots is greater than 190 volts and if so (contingent on the wiring status from the GFI testers), the relays would then both switch on (one relay for each hot line). A final test would be done on the output from the relays. A second comparator and transformer would test to see if the voltage AFTER the relays is greater than 190 volts, so that the functionality of the relays can assured. If one or more of the relays fails, both relays will be shut off. Good plan?
  4. #54
    19
    Has anyone run machines in parallel before? How would you hook up a remote? A Y-splitter? Any special precautions or adapters? Do the machines have to be the same? Running on the same output settings?
  5. #55
    Fraser Valley, BC
    593
    Miller has a pdf on there website that will tell you everything you need to know about parralleling.
    http://www.millerwelds.com/pdf/Paralleling.pdf
    Keep in mind, I'm pretty sure this will not work with remote amperage control Tig setups as each machine must always be ouputting the same amperage as the other.
    As far as the doo-hickey you keep talking about, the way I see it is if you are combing two different phases from to seperate leads, wouldn't you actually be creating 3-phase power? 3-phase= two hot leads and a common lead plus a ground, does it not? That is essentially what it sounds like you are trying to do. Might I also add, it sounds very dangerous.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
  6. #56
    19
    No. Three-phase is three-phase. I'm speaking of combining opposite phases of of single phase power. This is exactly how everyone else gets 220v, but I'm just trying to do it by linking power from 110v sockets.
  7. #57
    Nov 2007
    Ontario, Canada
    72
    The only machines that I've paralleled were two Lincoln DC600's. They were 3ph machines, so you had to make sure that they were in phase, then you wired them up so that one control board controlled both SCR drivers.
    Miller Spoolmatic-1
  8. #58
    Nov 2007
    Ontario, Canada
    72
    I think that that's rather complicated and expensive. Try to keep it as simple as possible. Use the meter.
    Miller Spoolmatic-1
  9. #59
    Vancouver, Washington
    51
    Tempriser
    You have lived up to your name. Certainly got this thread off and running. Keep in mind the longer the wire the more voltage is lost. With the setup you are proposing you will have unbalanced legs if the wire runs are different lengths. A normal 220v installation starts at the panel and always has the same length legs. That said it will work, I saw a dryer hooked up this way once. The guy just put an 110v plug on his dryer and ran some romex from another 110v plug on the opposite main panel leg and hooked it up at the 110v receptacle. The house was set up for a gas dryer and he had an electric one. Very scary. Whatever you do be careful because the wiring in the wall is a unknown and you will be potentially pulling amps most standard 110v receptacles will never see. The other issue is the breakers, it is possible you could damage your welder if you lose one leg of the 220v. In a normal installation both legs are hooked to a bridged breaker. No way would I ever wire a 220v receptacle in this manner too much chance of burning down the house. If you do burn it down the landlord will have a very good chance of winning a lawsuit. Or his insurance. What about just using a 110v welder?
    Paul
  10. #60
    Fraser Valley, BC
    593
    If you know so much, then why are you asking so many questions. If you combine two seperate phased leads, how is that any different than three phase? My Dynasty's main power cord is designed for three phase, to wire it to single phase you disconect one of the hot leads. Likewise, a three phase plug becomes a single phase plug if one of the hot leads is left unused, for instance a pigtail adapter with one wire left unhooked.
    If you want to parrallel your input power for a higher voltage, then I wold think you would want the two plugs on the same phase, but a different CIRCUT (breaker). And on the same note, shouldn't all plugs in a house be of the same phase? Consider, the power comes into the house in one main line, which is single phase and then sent through a stepdown transformer before being distriubted to the rest of the house. There is really no reason why a phase change should take place, so all the plugs should be the same phase.
    Makita 5" grinder
    IR SS5L compressor
