You just gave him a idea!!!!!!wasnt there a guy on miller,or hobart,that built a motorcycle in his livinroom?????????.Jack
Results 41 to 50 of 113
12-16-2007, 02:02 PM #41
- Jun 2006
- Killingworth,Ct.
- 372
Holy Cr ap
12-16-2007, 02:10 PM #42
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
12-16-2007, 03:05 PM #43
- Oct 2007
- Cave Creek Az
- 797
We need to hook this guy up with the guy that built his own welder from microwave parts, that guy was a piece of work too. I think they would make a good pair, and perhaps he could make this guy some sort of power transmogrifier to get him the power he needs.
12-16-2007, 05:44 PM #44
- Dec 2007
- Oklahoma
- 641
12-16-2007, 06:35 PM #45
- Dec 2007
- 19
Did you see my first post? They designed a product specifically for that purpose. 220 is simply two 110v lines with phases opposite each other, so that concept is sound. The question is, would this work with a welder? Since some run at 110v, you would expect that using 220 would lighten the load (double apparent voltage, divide current in half).
12-16-2007, 06:48 PM #46
- Jul 2007
- Carroll County, Maryland
- 108
Yea and I know a guy in NY selling a bridge and another in NV selling ocean front property. My point? Anybody can sell a fool anything.
This came from the website: "The Quick 220TM power tap technically uses the fact that 220 / 240 volts AC is supplied to most facilities. The 220 / 240 volts is divided into 110/120 volt circuits for distribution within the building. Using standard 110 / 120 volt outlets and the Quick 220, the user can quickly identify and connect to the separated 110 / 120 volt halves of the original 220 / 240, restoring the 220/240 volt AC option without adding new electrical circuits or wiring to the building."
I'm no electrician but if I read this thing correctly (and tempraiser you would be wise to read it carefully also) without having 240 already in the building the blame thing won't work. And I'm sure some help desk jockey will tell you it will work. Just my 2¢.The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird"
12-16-2007, 06:55 PM #47
12-16-2007, 06:57 PM #48
- Dec 2007
- 19
Isn't it usually advantageous to use two different phases in your house to balance loads? I would imagine that with luck and a long (and thick) enough extension cord, I should be able to find opposite phases. Making my own from eight-gauge wire might solve distance problems.
12-16-2007, 07:01 PM #49
- Dec 2007
- 19
12-16-2007, 07:11 PM #50
OK, take your meter and find two receptacles that are on opposite phases. Try to find the two that are closest together.
Get, or assemble two 14/3 SOW cables with 120V 15A plugs so that they will reach these two receptacles.
Run the free ends of the two cables to a utility box.
Into the utility box install a 240V 15A receptacle.
You will attach one black wire to one terminal and the other black wire to the other terminal.
Attach the green wires together to the ground terminal.
Attach the white wires together only to themselves.
Put an appropriate cover on the box.
Don't forget to use a cable clamp where the wires enter the box.
Make very sure you know what you're doing.
Find an electrician and show him your work before you plug it in.
Do not blow yourself up.XMT-300 with S-64 wire feeder.
Lincoln HI-FREQ modified to run XMT.
Esab PCM-875 plasma cutter.
Miller Spoolmatic-1
Miller PC-300 pulser
Miller Optima pulser
i have met many well beyond this guy, not that he isn't one, just not the worst.
