I just ordered a bernard gun for my mm175 cant wait for it to arrive
Results 1 to 10 of 23
Thread: just ordered the bernard gun
03-16-2006, 12:41 PM #1
- Sep 2005
- 8
03-16-2006, 05:29 PM #2
- Nov 2005
- Central Al
- 8
Mikemcc; I too have an MM175, and will be getting an replacement gun/cable assy.mine was damaged in a fire. Been looking at the M-25 15' at $191.00 + shipping. However I'm not familuar with the 'Bernard' unit. In what respect is this one your ckoise? I may consider it too. TIA for ya comment. Al
03-16-2006, 06:00 PM #3
- Sep 2005
- 8
free upgrade from our friends at bernard
check out the home page in the right lower corner..
select the gun then give them a call
03-20-2006, 03:09 PM #4
I thought that was for the industrial welders only? They did the swap for free on your MM175? Which gun did you get? All the options on their guns make it hard to choose.
Originally Posted by mikemcc
03-20-2006, 05:51 PM #5
- Sep 2005
- 8
just recieved it in the mailOriginally Posted by drscotch
it is for all miller welders personal or industral
i got the Q15 20 A O 8B M
you can order any combo you need..
it comes with 10 consumables also
cool
03-20-2006, 06:05 PM #6
- Sep 2005
- 8
opps this is the breakdown for the order
Q15 : 150 amps
20 : 20 ft. (6.16 m) cable
A : 150 Amp Curved Handle, Standard Trigger
O : Fixed, Short 45° QT2-45 neck
8B : 0.030" (0.8 mm) T-030 Centerfire contact tip
M : Miller® direct plug style
03-20-2006, 07:02 PM #7
Member
- Feb 2006
- springvale me
- 89
your going to like it a hole lot much more beefy than most guns and cables it has held up extremely well for me on a portable set up
garthswelding@aol.com trail blazer 301g with all the fixins:delta band saw dewalt chop saw craftsman drill press, sp-135 mm251 spectrum 375 suite case mig, tig w/hi freq. one welding truck.
03-21-2006, 02:40 PM #8
To clarify...
As part of the integration of Bernard guns with select Miller products, Bernard introduced the “Choose Your Weapon” Gun Exchange Program to ensure complete satisfaction. If your Miller industrial feeder or MIG system came bundled with a Bernard Q-Gun and it does not fit your needs or application, Bernard will exchange the MIG gun - at no additional cost - for any other configurable, air-cooled Bernard MIG welding gun.
To find configuration options for a replacement gun, call Bernard customer service at 1-800-946-2281 (US) / 708-946-2281 (outside of US), use their online CustomSelect Ordering System, or the Q-Gun user guide.
03-21-2006, 04:33 PM #9
- Sep 2005
- 821
I sure hope that 20 ft length doesn t end up burning up the little feeder motor on your MM 175.
03-22-2006, 02:25 AM #10
I'm confused?!!
I'm confused because from what I've read and after talking to Heidi over at Bernard.."mikemcc" Should not have gotten a Bernard gun exchange unless he ordered his MM175 with a Bernard gun from the start. if he had the standard miller gun that normally comes on a MM175 he wouldn't be eligible for a Bernard gun. Anyone else have any information on this..Administrator?
Mike can you explain more?
Regards, Farris
confused!Gone But Never Forgotten!
