Results 11 to 13 of 13
Thread: "Bucket Tipper"
    Well, I'm happy to report that the bucket tipper served it's purpose. It was actually a bigger convenience than I expected. I did not use much of the paint out of that 5 gallon bucket but thanks to the tipper (and a screw on pouring spout) I did not loose a drop due to spillage. I could have poured with it sitting on the living room carpet.....
    The mixer stand worked as well. But, as could only be expected there is a good bit of dripping from the "beater" once you raise it up out of the paint. I just put a bucket of water under it, lowered it back down and ran the mixer for a minute which cleaned the mixer like new.
    I am not a painter, and do very little painting other than with a rattle can so when I get that mixer stand back home I plan to make adapters to use it for other purposes. It needs a heavier base and since the upright is simply 2" tubing and the drill holder is bolted to a short bit of receiver tube which will slide on the upright post, it would not be hard to adapt the stand to just about any use that I can imagine. The bucket tipper will probably end up being the permanent storage location for a 5 gallon can of kerosene or diesel for the salamander when it gets home.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
    I like it! Don't often deal with 5 gallon cans, but dealing with 1 gallon cans into a mixing cup is hard enough.
    Jan 2008
    east central il
    23
    Default 55 gal drum pour
    Quote Originally Posted by dppmfg View Post
    that would make pouring the coolant in to a five gallon bucket much easier wonder if i could make one for 55 gal. Hmmm
    this is one i made for 55 or 35 gal drum
