Results 1 to 10 of 13
Thread: "Bucket Tipper"
    Jan 2009
    Whitehorse, Yukon
    279
    Default "Bucket Tipper"
    Here's one for all the autobody guys out there. Ever try to pour paint out of a 5 gallon pail into a 1 pint mixing jar? If the pail is full you almost always make a mess on your first try. Here is the solution I came uup with:
    Big Blue 400D
    Trailblazer 302
    Miller S-32 suitcase
    12VS suitcase
    Lincoln LN-7 (BIG suitcase)
    Victor torches
    Lincoln 350MP with 35' push-pull gun
    Lincoln PrecisionTIG 375
    Spectrum 1000 plasma cutter
    I like it alot. Any more close up pics or details of the hinges and the drum securing parts?
    Thanks, Scott
    Jan 2009
    Whitehorse, Yukon
    279
    The whole material list is as follows:
    1/8" plate cut into a 10" dia. circle
    16' of 3/4"x3/4"x0.100" tubing
    18" 1/2" dia. hot rolled mild steel
    36" 1/8"x3/4" flat bar
    3" 1" hot roll with 17/32" hole bored through
    10@ 1/2" flat washers
    2@ 1//2"x2" NC bolts
    2@ 1/2" NC nuts
    After boring (drilling if you don't have a lathe) the 1" round bar, cut 2 1" pcs and 2 1/2" pcs. the short pieces become part of the clamp system. The 1" pieces are for the hinge assemblies.
    Make 2 assy. for the clamps by welding a 1/2"nut, a 2" piece of the 1/2" hot roll and one of the 1/2" bushings together (repeat twice). I ran a bolt through each nut on the clamp assemblies and tacked a 1/2" washer to the end of it to make the pads. Put both of these on a 3" piece of hot roll with a washer tacked at each end. These make a small bar- or bessy-style clamp
    Hinges are the same type of thing: a 2" piece of hot roll run through a 1" bushing w/ washers welded on either side to eliminate lateral play.
    Clear as mud? Hope this helps-- If not PM me and I'll take some more photos this week. Cheers!!
    WH
    Big Blue 400D
    Trailblazer 302
    12VS suitcase
    Victor torches
    Nov 2008
    177
    Sweet idea! And a nice job.
    Professional firefighter (retired). Amateur everything else I try to do...
    Oh yeah: GO BIG RED!
    Dec 2008
    Arizona
    812
    I like it! Don't often deal with 5 gallon cans, but dealing with 1 gallon cans into a mixing cup is hard enough.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Jul 2006
    1,508
    Quote Originally Posted by nocheepgas View Post
    Ditto on that! Just yesterday painting a Red Face, first pour out of a gallon can of primer into the spray gun, now I have one gray boot!
    Caution!
    These are "my" views based only on my experiences in my little bitty world.
    Apr 2010
    Bronson, Fl
    168
    cool idea, Add an adapter for the space of a 1 gallon can and voila' multi use can pourer. Sweet deal, looks good miller blue too!!!
    Bob
    Before your post the only "bucket tipper" I knew about was a horse that would dump out his water/feed bucket.
    Since I had a little painting job coming up about the time you posted this I decided to build one of my own. I also made a "mixer stand" to hold my 1/2" Milwaukee drill with a paint mixing attachment. The stand is tall enough to be used with a 5 gallon bucket while it is in the tipper stand.
    Larry
    "I feel for the man who can only spell a word one way"......Mark Twain
    Lincoln AC225-S (OLD/Copper Wound)
    Lincoln Weldpac 100
    Miller Matic 180 (auto set)
    Miller Spool gun 100
    Miller Spectrum 375 Extreme
    Victor Super Range II
    Jul 2010
    central Kansas
    66
    that would make pouring the coolant in to a five gallon bucket much easier wonder if i could make one for 55 gal. Hmmm
    Feb 2010
    Oklahoma
    38
    Looks good and very practical.
    Miller 180
    >>>---Mat---->
