Results 21 to 30 of 34
  1. #21
  2. #22
    Mar 2009
    Corona, CA
    213
    Had the motor dyno'd today. Started out with a baseline of 390hp, and 469 ftlbs.
    At the end of the tuning session, had 448hp @5400, and 503 ft lbs @4100. Had about 2000 RPM worth of 460+ ft lbs. I have a feeling this motor is going to pull like a freight train in the truck...if I can keep traction.
    I have a sheet (though not currently on my computer) and I should be getting an email (of the same) as well as a link to a video of a pull on you tube. The guy was really cool about the whole thing, definitely had a good time spinning it. I'll add a link/picture when that happens.
    All in all, not bad for a 468 big block chevy on a budget, with pump gas and 8.5:1 compression.
  3. #23
    Evansville, IN
    2,348
    Here is the first rebuild of my old truck, It had and incident with a falling tree and it is a new project now, No pics except the old Blue truck. The bumper is a bit overkill but what the heck!
  4. #24
    Nov 2003
    3,421
    The bumper is cool.... keep sending pics as it progresses.....
  5. #25
    Mar 2009
    Corona, CA
    213
    One project leads to another it seems...in needing to work on my truck, I ended up building the guy that runs the shop a bumper for his 92 Bronco.
    I just finished mounting it to the frame the other day, still need to mount the fairlead and the skid plate.
    My project is getting wiring at the moment...slowly but surely.
    Here's a picture of the engine set up on the dyno though. I still havent scanned the dyno sheet in.
    http://c3.ac-images.myspacecdn.com/i...d03ed6ce42.jpg
    Pictures are in the following order:
    Modified piece of 3x3 1/4" tube to slip into the frame rail, and mount bumper.
    http://c4.ac-images.myspacecdn.com/i...f9c1b5c63f.jpg
    Test fitment on vehicle after everything was welded solid
    http://c2.ac-images.myspacecdn.com/i...d80c0948b1.jpg
    One of the welds on the side of the winch plate
    http://c2.ac-images.myspacecdn.com/i...8046c174d1.jpg
    A picture that shows how sturdy this **** thing should be
    http://c1.ac-images.myspacecdn.com/i...7691f79724.jpg
    I built it out of 1/4" plate, and 1.5" sq x .125 wall.
  6. #26
    Nov 2003
    3,421
    Very cool.... that bumper looks plenty stout...
    keep the pics coming... want to see that camper special as it progresses..
  7. #27
    407
    here is my continuing project. 1957 3100 1/2 ton truck. getting ready to lower it just a bit more. sbc 350/th350 with dropped straight axle and power brakes.
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
  8. #28
    Baldwin, NY
    275
    Still working on it, it's sitting in the corner of the shop now waiting for the next cam, and oil pump.
    12.2:1 compression on stock pistons 346 ci LS1. Pistons flycut .090" for valve clearance, .036 MLS head gasket, cnc ported then hand finished ls6 heads milled .080 and chambers welded from64 cc to 58 cc, 2.00 hollow stainless intake valve, 1.55 hollow stainles exhaust valve. Both tuliped and undercut. Cam is a custom grind 247/252 duration @ .050 .647/.647 lift. 109 lsa, 107 ICL.
    Intake is a custom ported edelbrock supervic with a fast 4bbl throttle body. I made the aluminum an block adapters from 1/2" aluminum.
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
  9. #29
    Mar 2009
    Corona, CA
    213
    That should be a really sweet engine when you get it in the car, looks awesome on the stand.
    As promised, a few more pictures of my old chevy.
    http://sphotos.ak.fbcdn.net/hphotos-..._7033088_n.jpg
    http://sphotos.ak.fbcdn.net/hphotos-..._4696683_n.jpg
    And a scanned image of the dyno sheet, and graph.
    http://sphotos.ak.fbcdn.net/hphotos-..._6937167_n.jpg
    http://sphotos.ak.fbcdn.net/hphotos-..._6328893_n.jpg
    I just put the front end parts on the other day...waiting for more stuff, like springs and such. Hope to have the engine/trans in it by the end of this weekend. As soon as I have a video of the engine running, either in or out of the truck, I'll try to link to that as well.
  10. #30
    Baldwin, NY
    275
    Well, just got off the dyno, made 502 hp to the rear wheels, 400 ft lbs torque. Stock rod's, pistons and crank, 346 ci... made 500 hp @ 7100 rpm and carried 490 all the way to 7600. Should do 9's in my 2800lb camaro.....
