Thread: rod oven
    Feb 2010
    27
    Default rod oven
    does anyone happen to have a set of plans for making a rod drying oven? i have a small work shop (12x16) and i need to make something small. thank you
    Jul 2008
    Oklahoma
    56
    Tim,
    Does this need to be code compliant?
    jrw159
    ASW CWI / ASNT ACCP II / CWB Welding Inspector / CWB Welding Supervisor / PT Level II / MT Level II
    Feb 2010
    27
    no it's just something for my home shop . thank you
    Jul 2008
    Oklahoma
    56
    Tim,
    Since you are not in a code situation you need to check the manufactures recommendations for baking and storage. Since you did not give any info on the electrode you are wanting to "bake" I would guess (hate to do that) they are low hydrogen electrodes.
    For storage you are going to be looking at roughly 250F. For baking roughly 700F. These are the low end temps from D1.1 and should pretty closely match the manufacturers recommendations for low hydrogen electrodes.
    As for making a storage/baking oven you may find something if you use the search function but it may not achieve the recommended holding temps.
    I suspect that unless you just really want to make your own you might be able to find one used just as cheap.
    jrw159
    Feb 2010
    Houston, Tx.
    378
    How many lbs. of rod do you need to store in the oven? Some of the smaller ovens, say 10 lb. capacity, are pretty affordable. When I say affordable I mean the price difference between building one and what a factory built one would cost. I have seen used ones for sale on Ebay. they are usually the larger variety out of an industrial facility. The small ones do come along now and again, but I really did not note the average price used. Then you also have to tack on shipping $$$. I should mention that these were storage ovens and did not get hot enough to bake a Lo Hyd. rod that had been out for a while. Phoenix rod ovens has some smaller models.
    Sometimes there's no second chances.
    360
    I bought a used Gullco for $100 from my local equipment rental store. Can't build one for that.
    Feb 2010
    27
    ok thank you for the help guys
    Sep 2008
    ****son,TN 37055
    34
    I needed a "non code" oven for my home shop use. I used a piece of 8" pipe with a 6" electric stove eye in the bottom of it. I've got an old dutch oven lid for my top on it. It seals, but not very well. I stuck a pocket type thermostat in it and it's holding at appx. 200*F. It's hold around 15-20 pounds of rods. I keep my leftover, opened Lo-Hy's in it. I need/want a portable oven for the truck, but this has worked for the time being.
    Nov 2008
    Colorado Springs
    276
    I used an old electric oven I picked up at a garage sale for $50. Set it at 250deg. Did that for about 6 months then bought a 20lb unit, and sold the oven for parts.
    I broke even on the old oven and I like the factory 20lb portable alot more.
    Online new units are from $150. to $1500. depending on the size
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
