Results 1 to 10 of 14
Hybrid View
    northern NJ
    1,884
    Default trailblazer problem
    I have a TB250G, 1100 hrs. Thursday went to a job & welded about 15 ft. with mig & when I went to grind, welder revved up but no 110v power. Swapped grinder, eliminated ext. cord, checked breaker resets, all o/k. Shut off machine while thinking, started it up to see if it would weld & it had 110v power now. Finished grinding, grab the gun & now no juice to the feeder. Shut it down & started it up again now all is well. Friday no problem. Today on my second job I was stick welding & changed rods & now it won't weld. Checked all the connections, flipped switches, nothing worked so I shut it down, started it back up & it worked fine. Happened again a little while later & after shutting it down it worked fine again. Finished up the last couple rods & packed up. Now I'm worried about it crapping out somewhere in the middle of an important job. I don't know where to start to look, any ideas?
    MM250
    RCCS-14
    Feb 2009
    Lodi, CA
    1,294
    What year was your 250G manufactured? You can do a little searching above, under "resources", with your serial number you can find out.
    I had the exact same problem, with one made in 1988. Ran into a Miller rep at a trade show, called him a few days later with a serial number, problem was something to do with the exciter. He sent me a new circuit board, with a red push-button switch, some wires, and instructions, free, this was a factory update dealing with a defect in this machine, manufactured at that particular time. My little brother was an electronic tech at the time, had no problem doing the install. Anytime after that, if the power went off, the red button glowed, just push it, and keep welding/grinding.
    northern NJ
    1,884
    JH184714 which makes it a 1987. I'll have to check with Miller about the exciter. This is the first time it's happened.
    Last edited by MMW; 07-31-2010 at 08:24 PM. Reason: changed last 3 digits-174 to 714
    MM250
    RCCS-14
    Oct 2004
    Edmonton, Alberta
    8,020
    Check your oil level, possible dirty slip rings, slip ring brush not making contact or weak control bridge?
    northern NJ
    1,884
    Oil level is good. I'll check the brushes & slip rings tomorrow or Monday.
    MM250
    RCCS-14
    northern NJ
    1,884
    Checked brushes/slip rings & they looked o/k. Cleaned slip rings & brushes with 150 paper & then 400 today. It is working now so I hope it stays working.
    MM250
    RCCS-14
