Results 1 to 10 of 10
    Jul 2009
    Australia
    1,031
    Default Can Argon Gas Bottles Be Stored Horizontal
    Can our Argon welding gas bottles be stored horizontally?
    Our new supplier of E size bottles dropped off their first one on Friday.
    I tried to install over the weekend but quickly discovered that their bottles are 100mm or 4" to tall to fit under my welding bench like the old bottles do.
    The only way now is to lay it down on the floor.
    Will this be okay or does the compressed gas turn liquid and start splitting out of the torch?
    Ji
    Grip it and Rip it
    Sep 2008
    Estevan, Sask
    111
    Argon or oxygen bottles work fine laying down. As far as I know, there is no liquid, only gas. Unless the gas turns to liquid on your side of the equator?
    Mar 2010
    245
    sounds dangerous, if you are going to lay it on the floor/under a bench, plenty of things to fall on the neck and kill or injure someone, the safest way to store a bottle is upright and chained against a wall. just buy a longer hose.
    even those little bottles will go all over the place.
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    Jul 2009
    Australia
    1,031
    Thanks for the replies.
    It is only compressed gas so no liquid, even down here.
    I will place it on the floor under the bench.
    My bench is enclosed on 3 sides so no chance of anything falling and hitting the valve. I will even make a cover for the valve just in case.
    Ji
    Grip it and Rip it
    arkansas
    781
    Quote Originally Posted by stugots View Post
    even when working on a spaceship....
    welder_one
    www.sicfabrications.com
    Dec 2009
    Midwest
    581
    This topic has been thoroughly beat to death on half a dozen boards.
    You would think people would have had enough flaming each other over it.
    Do a search over on welding web or AWS & you'll see it for yourself.
    So you're telling me...You're not nostalgic? Then, give me another word for it......
    Jul 2009
    Australia
    1,031
    Hi 7A749,
    I don't look onto any other welding forums just this one.
    I now have the answer I was looking for so this should just fade away.
    Ji
    Grip it and Rip it
    Mar 2010
    245
    Quote Originally Posted by welder_one View Post
    thats a trick question, you dont need any shielding gas on a spaceship!
    Lockheed Martin
    USW local #3185
    Jul 2009
    Australia
    1,031
    Hi Griff,
    I asked about Argon bottles not acetylene
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    Hi Griff,
    No biggie.
    Lets let this topic fade away now.
    Ji
    Grip it and Rip it
