Results 1 to 3 of 3
    May 2010
    Weaverville ,NC
    34
    Smile Wall mounted concrete sample rack... Organizability! Learned something.... finish!
    http://www.flickr.com/photos/fab-slab/4824681285/
    http://www.flickr.com/photos/fab-slab/4825290732/
    These are a couple of pictures of some concrete sample racks I welded up.
    The samples are 5"x5"x1.5" a piece and 2.5 pounds in weight.
    I was sick of having them just take up table space.
    I set up a fixture, cocked a piece of 3/4 angle just so that the samples would lean back with gravity, and stay put.
    The eye opening part was when I primed and spray finish painted the racks.
    They looked waaaaaaay better than I imagined.
    I guess I felt what I cobbled together didn't rate a good finish...(I've been waxing everything I've made)
    It makes a WORLD of difference to actually tighten up the project with finish paint... Duh, where have I been all of my life?
    Millermatic 211 MIG
    Miller Spectrum 375 Plasma Cutter
    Milwaukee 6190-20 Dry Cut Saw
    Jet HVBS-56M Band Saw
    Jet 708595 Bench Top Belt/Disc Sander
    www.slab-fab-studio.com (Fab Steel and Concrete Furniture Site)
    www.billysproul.com (Found Object/Sculpture Site)
    Jan 2009
    Ohio
    191
    Default Displays
    Hey looks real nice great way to show the samples.
    Vernon
    Mar 2009
    Michigan
    138
    Default Nice!
    I made something kind of like that, but our samples are 12.5 x 12.5 x 1/2
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
