    Jul 2010
    British Columbia,Canada
    11
    Default miller blue star 2e
    i have a miller bluestar 2e dc welder it worked fine except it was leaking gas from the carb so i took it apart and put it back together ,i fixed the leak but do not know the settings ,does anyone have a parts breakdown for the carborator and what the settings would be so i can get it to run properly any help would be appreiciated
    Aug 2008
    Orange, TX
    1,215
    I don't have a break-down handy but a typical starting point on mixture settings is usually 1-1/2 turns out from seated on both idle and main jet adjustments and go from there with the unit running.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Jul 2010
    11
    is the main jet setting the spring loaded needle valve on the bottom of the float bowl?
    Aug 2008
    Orange, TX
    1,215
    Yes.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Aug 2010
    ky
    Smile miller bluestar 2e
    yes i just also bought a miller bluestar 2e ac/dc ive seen a bunch or heard of a bunch with blown motors with the Techumseh engine and was wondering if they r good welders and if i bought a good welder or a peice of junk thats goin to blow in three weeks i have welded with it and welds good but was just wondering if the motors r junk or not thanks
