Results 1 to 8 of 8
Hybrid View
    Apr 2008
    253
    Default running gear spindles
    Id like to make 2 or 3 sets of 8 ton running gears (for stack wagons). Im having trouble tho finding axle spindles rated above 3k pounds/pair. Anyone know of a source for these?
    Aug 2007
    arkansas
    781
    8 ton axles...hmmm.... big truck and trailer parts?
    welder_one
    www.sicfabrications.com
    Salem ,Ohio
    3,671
    Cool
    Quote Originally Posted by welder_one View Post
    Yeah like out of a cement mixer chassis. I rented a tow dolly and it had spindles that turned and thats what they looked like...Bob
    Sep 2006
    273
    Southwest tire and wheel, dallas axle, google trailer supplies. Here in north Texas we have a variety of suppliers for stuff like that. Up to 7k per pair are pretty reasonable. Above that, not so reasonable.
    Apr 2008
    253
    Thnx! Was thinking along the lines of junkyard scavenge but then thats not a constant source of parts. Eventually Id like to make several wagons.
    Harv...thx for the lead. Ill look into that.
    Very much appreciate all the helps.
    ETA: Just for the record Im only interested in the spindles. The axles for these wagons are heavy walled tube and the spindle is welded onto that.
    Apr 2008
    253
    Ya know, on second thought...I assumed, incorrectly I think, 8 ton gear meant 8 ton spindles. After some thought Im not sure that assumption is correct. I think it means the gear has a gross capacity of 8 tons which would be evenly, or mostly so, distributed over 4 spindles. That means each spindle would only have to support a ton. Am I understanding this correctly?
