Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 55
  1. #21
    May 2010
    Central CA
    788
    Default more pix
    Sonora Iron, Yes that's the bracket. I add to my favorites.
    SA-200 Small 012.jpg[ATTACH]SA-200 Small 005.jpg[/ATTACH]
    Don't know how I made this mess.
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
  2. #22
    May 2010
    Central CA
    788
    Default one more time
    This is to hard, still don't how to do it.
    The exhaust manifold says red seal on it, the pipe is brazed to the manifold, and the muffler is welded to the pipe. So that means the hood will not come off.
    So after all this what do you guys think?
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
  3. #23
    Jul 2006
    1,508
    Quote Originally Posted by Bob Miller View Post
    Where in California is that puppy?
    It's a very nice looking machine, the question is: What is it worth to you?
    Caution!
  4. #24
    Jul 2006
    1,508
    I'd start that thing up, take a port a band and wack that muffler off above the hood, and get a rain cap or 90° turn. People run straight pipes all the time. My 1550 RPM machines have mufflers, but the 1400 RPM machines do not. The 1400 RPM machines are quieter!
    Caution!
  5. #25
    May 2010
    Central CA
    788
    It will be just a toy for me. I just want to see what all the fuss is about.
    I'll take it out and play with it once in a while, That's if I get it, if it's gold I might pass.
    One of the pointers (fine adj) is smaller than the other, both are rusty.
    It's a 1/2 mile down the road from my house. I am between Stockton and Modesto.
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
  6. #26
    May 2010
    Central CA
    788
    Default 1550
    This machine says 1550 high idle on the face plate.
    Who ever welded the muffler on, welds like I do, one wack with a hammer and it will fly off. In fact the ball hitch was welded on by the same guy as well as the home-made fenders.
    If I get it I would cut the fenders off and grind it smooth, touch up the paint.
    Then roll some 3/16 with 1" lip on each side weld that to a 3/8 or 1/2" bracket, and bolted it to the axle, so it can sit down close to the tire and never rub. I've done that for my tractors and that works out real nice.
    My thinking now is I going to pay through the nose.
    You know the more you guys say how good it is the more I"ll have to pay.
    Thanks again,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
  7. #27
    Jul 2006
    1,508
    With that tool arsenal you have in your signature I doubt that very much. I'm sure you're good enough at welding to appreciate the quality of arc these old girls produce.
    Caution!
  8. #28
    Oswego IL
    826
    Default Only way I would buy that welder would be if...
    It was cheap, I mean very cheap. Or if I was restoring an early 70's truck to advertise my business with. Plus what does one weight??
    Kevin
    Lincoln ranger 305g x2
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
    F550 imt service truck
  9. #29
    Oswego IL
    826
    Default Forgot to mention....
    If you do buy that welder I would highly suggest removing the spark plugs, and putting a cap of oil in each cylinder, then turn the engine over by hand. Next take the igntion cap off clean the contact areas, and check the points. After you get her running do an oil change, change spark plug wire, and a coolant flush.
    Kevin
    Ln25
    Miller spectrum 625
    Miller 30a spoolgun
    Wc115a
    Lincoln 210mp
  10. #30
    Jan 2008
    328
    Default Neat little trailer it comes on
    If you cannot lower the fenders much I would unbolt the axle and put the axle under the springs. You may or may not need to flip the spring saddles to the other side of the axle. The short axles are often straight and do not have a top or bottom to them. This will allow you to lower the fenders a couple inches. A lazier way of doing it would be to put 2 smaller wheels on it. They used to often use 14" or 15" rims, thus having a 27" or bigger tire. Now they usually use 13" rims and the tire is about 23.5". Some are rated 1100#, most 1360#.
    If you decide to pass on it, I might be interested in buying it for a project.
