Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Sep 2009
    Arizona
    38
    Default Homemade Patio Table
    Decided to build myself a patio table. the top is from 2inch angle, the legs are 1 1/2 square, and the cros braces are from a old set of bunkbeds, because i did not want to stop and go get steel. same goes for the little piece of 2 inch pipe i used going through the leg braces, its a old piece of car exhaust. the shape is a decagon (10 sides). figured a square was too easy. With the frame done i went on to do the top, to help me fill the 2 inch angle, i used 1/2 inch plywood, 1/2 inch cement board (about 2 days after i cut i found out they make a lighter product, hardy wonderboard backerboard, would have saved me about 30lbs). then finally the terra cotta tile which is around 1/2. of course there is mortor in there. used a dark brown grout, and a leather brown paint for the frame. the finished peoduct weighs around 200 lbs :eek:. i figured if it gets stolen weighing that much, they had to work hard for it, so they can have it. overall it was a fun project. i got to learn alot with it.
    1. im not too good at math, but thats ok, my father in law is.
    2. just because im a fire fighter does NOT mean im fire proof. was wearing my "lucky" jeans, with holes in the knees and they flamed for a minute.
    3. wearing ear plugs while welding is a good idea, welding off angle, got a spark in my ear.
    4. No plan survives first spark.
    Hope you enjoy the pictures, sorry they are out of order. :)
    Flash me, Im a Welder
    Sep 2009
    Arizona
    38
    Sep 2009
    Arizona
    38
    Sep 2009
    Arizona
    38
    Sep 2009
    Arizona
    38
    Sep 2009
    Arizona
    38
    that should be all of them
    it looks great man, and i just have one rookie question. How did you figure out the degree of cut to make it round? thats the only thing that messes me up when building anything, is figuring out the angle that i need to cut.
    Mar 2010
    245
    60degrees X 6sides = 360 circle
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    alabama
    715
    Quote Originally Posted by stugots View Post
    Might wanna count again.
    XMT 350 cc/cv
    XMT 350 vs
    TRAILBLAZER 302
    MILLER DVI
    PASSPORT PLUS
    DYNASTY 200 DX
    MAXSTAR 150 STL
    HOBART CHAMP
    HF-251 BOX
    12-RC SUITCASES
    12-VS SUITCASE
    arkansas
    781
    4 sides, 6 sides, 10 sides, 190 sides............ makes no difference..... divide the sides into 360, and you get the required angle set.....
    welder_one
    www.sicfabrications.com
