Results 1 to 3 of 3
    two rivers wi.
    23
    Default miller 140 auto ser
    If you are going to weld two pieces of metal together, one is 1/16'' thick and the other is 1/8'' thick. What does the manual say, do they give you an approximate setting for the two. Or is it only for one size only.
    Rob
    Thanks Rob
    http://www.1969supersport.com
    Jun 2007
    Scotts VAlley, CA.
    39
    Arrow
    Rob,
    I was taught that you set up for the thicker piece, and dwell less on the thinner metal as you do your pass. Best thing to do is take a couple of test coupons, and just run a few beads to see what setting and speed works for your skill level.
    Hank
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Meco, Victor, O/A
    two rivers wi.
    23
    Sounds good, thanks Hank
    Rob
    http://www.1969supersport.com/
