Results 1 to 10 of 19
    Jul 2009
    Australia
    1,031
    Default MX Foot Peg Widener
    Vintage motocross bikes pre 85 and older had very small foot pegs. These small pegs offered little grip in the wet and have evolved over the years to the large ones of today.
    To bring these pegs up to date you can purchase large new ones if someone is manufacturing them for the bike you have, if not you can improve the existing ones by welding wideners on. There are some companies that manufacture wideners which can be purchased and welded on. I decided to make a set for one of my bikes and this is how I did it. This is not the only way to make them and this whole thread can be concided as entertainment by those that all ready know all there is is know.
    First I purchased some 20 x 3mm stainless steel plate.
    I then marked it up and started drilling out the holes required to make the serrated pattern I like.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    Then I used a band saw to cut the profile of the serrated teeth.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    Once the cutting is all done I used a file to finish off the profile.
    Then I placed the plate into a bar bender.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    Hey presto I made a foot peg widener.
    I have to cut to length and then bend the other one.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    With both profiled and bent they are now ready to be welded onto the existing foot pegs.
    Ji
    Grip it and Rip it
    Apr 2010
    Bronson, Fl
    168
    Look good to me. My YZ has wide pegs, but those are just fine. Good deal!!
    Bob
    Jul 2009
    Australia
    1,031
    Hi Rbeckett,
    I made these for a Yamaha YZ125 1981.
    The original pegs only measure 30 x 67mm.
    With these wideners welded on they will be 49 x 80mm, similar to modern peg size.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    1,031
    I have not TIG welded a lot of stainless steel so yesterday I grabbed a few couplons, fired up the TIG and broke out the 316 filler rods.
    Not the best weld but good enough for this project.
    I will do some more practice before I finish the project.
    Ji
    Grip it and Rip it
    Dec 2008
    Arizona
    812
    I wouldn't want to wreck and have those teeth rip my leg off!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Jul 2009
    Australia
    1,031
    Hi nocheepgas,
    Your right I wouldn't want that either.
    I left the teeth long at this stage.
    When they are welded on I will reduce, level and round them with a file.
    Ji
    Grip it and Rip it
