Results 1 to 10 of 10
    Jun 2010
    21
    Default Any ideas for a security "cage" (i.e "thief proof") for little Honda generators?
    I'd like to make some type of secuity "shark cage" to keep the theives (sharks) from stealing my twin Honda EU2000 generators while at campgrounds. Simply running a cable or chain through the handle of the generators won't cut it. The handles are made of plastic and can simply be cut away with ease as well as total silence in the middle of the night. I'm thinking that a metal "cage" would allow easy access to the generator controls and allow cables/cords to run through without a problem. More importantly, it allows the generator to cool and "breath", unlike a steel box with just a few holes in it.
    If anyone knows of any ideas with pictures, I would be greatly appreciative if you could post 'em.
    Thanks.
    Dec 2009
    Northern California
    179
    You could check out a Material Handling surplus that buys and sells used pallet racking materials.
    You could find some odd sizes of the wire rack decking that is welded together like a grate and cut them to size and then weld them together to form a box.
    You could make a base frame and maybe add some off road casters to make it more portable and then you could chain it to a post, tree, camper whatever.
    Another option may be to get one of those garden style carts at the home centers that are constructed with a mesh base and sides and enclose it in to do something similar to above...
    Oct 2009
    Reno, NV
    299
    Default Cage?
    I say just let them sit out there with no "security" other than you and your buddies with their .357 Magnums. If someone shows up to steal YOUR STUFF, just point the guns at them and ask them to lie on the ground and pee in their pants like real "sharks". Once they have done that, take their wallets, cell phones and anything else they might ahve and then just offer them the choice...leave and DO NOT come back or DIE!
    Don J
    Reno, NV
    Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
    Sep 2006
    316
    The down side of what you've suggested is two thieves could easily pick up the cage and run off with both of your generators.
    Back in the day I did contract telco work. We had men working in manholes with generators running cabled to their trucks. The thieves would cut the cables and load up the generators still running. The guys in the manholes wouldn't realize there was a problem until the extension cord came unplugged. By the time they got upstairs most of the time all they would see is their cord laid down the road.
    I have one of those generators. I've had it about four years now, love it. When I've dry camped out in the parks of Arizona I've just cabled it to the gooseneck on the toyhauler. I always figured anyone that took the time and effort to cut the handle on the generator would be taking a big risk a couple of ways. One of course would be getting caught. The other is they would be real hard to move, most of the thieves are druggies looking for a quick buck, damaged like that.
    A dealer in Flagstaff told us those generators were the hottest thing when it came to targets for thieves.
    May 2010
    Central CA
    785
    I built a cage for a honda 5 hp motor on a mixer box. It was bolted to a plate so it was easier than what you have to work with.
    I welded SS angle iron over the motor so tight you can not remove the motor with out a plasma.
    I use SS incase they came back with a torch. I heated the SS before welding it on, so it would to hard to saw.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Aug 2007
    arkansas
    781
    just start stackin pieces of metal around this gen set until you feel its safe..... then start the hot glue gun and glue it all together... a honest man cage isnt a brain surgery cage...
    welder_one
    www.sicfabrications.com
    Apr 2007
    Eastern Ontario
    101
    I'd make a tree to hold them and padlock the center of the tree. Couple padlocks to hold each one in. If this is not secure enough, can add a front / back circle as well.
    May 2010
    Central CA
    785
    Default Big Cage
    I am building a big cage for my booster pump (8'LX8'HX6'W) out of 2" Sq tubing and 9ga. expanded metal.
    I have a problem with the radiators disappearing at night.
    When it happened the first time I put tamper proof bolts.
    When it happened the second time I welded the bolts.
    So far the welded bolts are working (knock on wood), but as soon as my leg is healed I will finish the cage.
    Good Luck,
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Jun 2010
    21
    Thanks everybody for the great recommendations. I really like the "tree" idea with the graphics. It made me think of some great ideas. Also the 9ga expanded metal idea sounds really good. I just need something for those certain campgrounds that have a lot of people.
    Generally, I prefer to "boondock" out in no man's land where I don't have to worry about thievs. However, when I'm in a local campground with a group of people that we go with, sometimes there is a chance of a homeless guy comming around when everyone is asleep and tries to walk off with stuff.....
    Thanks again everyone!
    Oct 2008
    5
    A buddy of mine had two versions that he used with his camper for similar gensets. The first one he made himself, basically a box that padlocked to the top of the tongue and covered everything. It had 1" slots on all the sides for air and he installed a fan on the side for cooling.
    The second version that he is currently using (after jackknifing his trailer and destroying his box ) is the basket from a grocery cart flipped upside down and using the same hinge he had on the first version.
