Results 1 to 2 of 2
    Blissfield, MI
    78
    Default Log splitting the easy way!
    Here is a pic of this weekends project. I took a log splitter that has been sitting around for years and mounted it to my Bobcat! It has not been blasted and painted yet but it works great! Mounted it upside down so I can do everything from the seat. You can even tilt it down to roll and position the logs the way you want them! I left the original mounts on so when I build a bigger one I can cut it off and use it on the 3 point again. Anyone have ideas on the new one? I want a cylinder with a 48" stroke. This one has 32" and would be nice to split longet pieces!
    Modern Metalworking L.L.C
    Blissfiled, MI
    517-605-9481
    Miller Dynasty 350 Tig runner
    Hobart 3-phase mig
    Hypertherm 1000 plasma
    Mill
    Lathe
    Box break
    Shear
    Indiana
    541
    Looks good. I saw one on ebay that is mounted parallal to the bobtach plate.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
