Results 1 to 3 of 3
Thread: Shooting Bench
    Dec 2009
    Custer Park, Illinois
    92
    Default Shooting Bench
    Made this shooting bench a few years ago when I was prairie dog hunting out west.
    The legs are removable and individually adjustable for uneven ground. They mount with shoulder bolts held in with wing nuts. They store inside the main tube for transport.The threaded rod on top is for height adjustment. Never did get any knobs put on the threaded rods.
    The main tube is 3" pipe with the union half welded in place. On the table top is a short piece of 3" pipe threaded for the other half of the union and welded to the table bracing. The union nut has rods welded in place to tighten and loosen the union so the top will swivel 360 degrees.
    The table top is 1/2" plywood with 3/16 stiffeners underneath. There are quite a few prairie dogs in Wyoming and North Dakota no longer with us so it has proven to be steady.
    The paint job is what I call prairie dog camouflage.
    Al
    Miller Dialarc 250 HF
    Lincoln Classic 300D
    AutoCAD 2010...Paper Is Cheaper Than Metal
    Hypertherm Powermax 45
    Milwaukee & Hilti Power Tools
    John Deere Equipment
    Paints and Quarterhorses
    Billy Cook Roping Saddle
    Billy Cook Reining Saddle
    Our YouTube Channel
    Sep 2008
    Anchorage, Alaska
    98
    Pretty spiffy; however, the shooter seat location is on the wrong side.
    Jerry in Anchorage
    Dec 2009
    92
    Had a buddy I used to shoot with said the same thing.
    Al
    Our YouTube Channel
