Results 11 to 20 of 21
    Jun 2007
    Washington State
    6
    Default 110 Welders
    Don't sell the 110 mig machines short. I have had two, both Lincolns, the first wore out after years of steady use and abuse. The second one is still going strong. I wouldn't want to be without it. If I replace it it will be with a MM140 (not auto set). They are easy to carry around and very versatile. They are limited with solid wire and gas. Best really for 1/8" or less. With .035 and flux core wire you can easily weld 3/16" to 1/4". The keys are, absolutey clean metal, very short "stick out" and proper speed. They will run off a small generator and can be plugged in anywhere.
    For a first welder they are perfect, but can't be compared with a 220v machine like my MM210. But they are not competing. Go with the MM140,
    you won't be disappointed.
    Bob
    Scottsdale, AZ
    173
    Quote Originally Posted by opsranch View Post
    Bob
    Why NOT auto set? That said even tho I am all new to this I am not sure I would want it because I would rather do my own adjustments...but I want to hear what a pro thinks.
    Albeit I started out with a MM140/110V I found nothing but limitations. But then I work on my Jeep and most of the stuff I do is 3/16 to 1/4. Not being a pro welder and having a smaller machine only held me back. I am SURE that if I were a better welder it is not a problem.
    Same, same in my world of computers. An expert user can get by with a LOT less RAM than a novice. But then you "know the ropes".
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
    Jun 2007
    Washington State
    6
    Default Why not auto set?
    Don,
    Auto set seems to me to be too limiting. When you are welding different types of steel (I use a lot of scrap that is of unknown origin) in different thickness, its nice to find that perfect heat and wire speed to make it weld nice, like welding 10 ga sheeet metal to 1/16" or 1/8" angle. Inside my MM210 I bought in January there is a chart that gives the recomended settings both steel and aluminum (that dual gun set up is so cool), I've found that they are just a place to start. Each job with new materials, positions, and weld type
    needs to be fine tuned. That's all I meant. My experience with auto set (with a 140) is about 10 minutes, so I am no expert.
    Bob
    Scottsdale, AZ
    173
    Don,
    Bob
    That was my thinking, but what would I know. True, it seems that everything I do I have to "fine tune" wire speed and amps. So far what I have noticed is that my MM180 always needs less amps/wire speed than the chart calls for.
    Yes auto set seems more like a gimmick type thing to me.
    Thanks for the reply.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Default keeping an open mind
    If you'll keep an open mind and perhaps consider some smaw. I'd take a look at a thunderbolt xl 225 ac/dc. its 220v and takes more skill but for a low price welder I don't think you can beat the quality. I think you'd be happier with It than with a low price 110 volt mig machine with a short duty cycle.
    Just trying to get you the most for your money.
    Rick
    Nov 2007
    Central Idaho
    190
    Default Passport
    I'm stunned that no one has recommended the Passport! True, the initial cost is a little steep (about double the 140) but it's got it all. It will run on 110 or 220. It's rated for 1/4" on 110 and 3/8" on 220, better than the 180, and the same as the 212. It weighs 45 lb. compared to 72 lb for the 180, and 192 lb for the 212. It has an internal gas bottle for onsite work, as well as a fitting for an external gas source. It also has a setting for stainless, and the case is practically bulletproof.
    I have a 175 in the shop and the Passport stays in the truck. But if I could only have one wirefeed, it would be the Passport.
    Scottsdale, AZ
    173
    Quote Originally Posted by mikeswelding View Post
    Not sure if ANYONE can toss at rocks at a passport...what could be one of the best welders on the market today.
    That said I wrestled with that but the MM180 won.
    1) I see little need for a portable unit and where I go that I would need one is off road and there is NO place to plug it. This means some serious mods and $$ on my Jeep to bring it with me. Dual batteries, alternators, switches etc.
    2) There are several welding set-ups that are overall better for remote use in my Jeep.
    3) I have no desire to be the trail "welder-ho" for sometimes as many as 30-40 Jeeps on a trail run.
    Bottom line my welder stays in my shop and I saved some bucks...besides my wife said if I spend that much money on the Passport I don't get my Hypertherm Powermax 30 Plasma cutter I just picked up Monday. 1 MM 180 + 1 HPM 30 = Happy Happy Joy Joy Vs 1 MMP. You do the math But I would SURE like to have one.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Appleton, WI
    7
    Default A little more info on the Auto-Set
    I just wanted to throw a few comments out on the Auto-Set. It is a great machine because it is actually like having two machines in one. First there is the Auto-Set feature, which really does work well. Yes I am a product manager for Miller, but I am also a huge car guy. I don't weld everyday, more like every couple of weeks, but the welder I use most is a MM140 Auto-Set. And because I don't weld everyday, most of the time I do use the Auto-Set feature.
    What I really wanted to clarify is that the Auto-Set machines can also be set in manual mode just like all Millermatic welders. The parameter chart is still on the inside of the door and both the voltage and wire feed speed knobs can be infinitely adjusted, for those circumstances when you don't want to or can't use the Auto-Set feature.
    Hope this helps!
    Jon Ertmer
    Product Manager
    Miller Electric Mfg. Co.
    Scottsdale, AZ
    173
    Quote Originally Posted by Miller_Jon View Post
    Hope this helps!
    Jon, that was helpful and I think having the duality of the welder is truly a bonus. Kinda makes ke whish I had bought the 180 autoset now. But my exp albeit LIMITED in welding is that every time I go to weld requires a fine tuning. I do know that as time goes by and my skills improve some I make some adjustments of my own at the arc and how I manage the puddle...but that comes with time.
    But I do LOVE my MM 180 and truly feel it is a major step up over the MM140 for the world in which I weld...on my off road Jeep. I weld in a space that covers 1/8th - 1/4 with heavy emphasis on 3/16th.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    georgia
    10
    I don't know what kind of garden items you want to weld but i don't think you will be happy with a 110v welder. I would aim for a small 220v mig even if it means adding a 220v plug. Just my .02...Bob
    i agree you want be satisfied with a 110 volt not hot enough.
    my ability is limited by me only.
