Results 1 to 10 of 17
    Default Anyone make ther own welding lead reel?
    I am thinking about making a couple reels for my welding leads after seeing what one of the welders made. I would like to hear any suggestions and tips that you guys have to offer. Thanks in advance.
    Synchrowave 180 Tigrunner
    Millermatic 251
    Trailblazer 302
    Spectrum 375
    Central Miss
    14
    heres a set i made
    no bearings, and they aren't hot, so it was easy to make
    just plug in jumpers from machine to reels and you're ready
    dave
    Jan 2009
    Ohio
    191
    Default Welding Reels
    My Dad made a set that held over 100' and could be turning and welding at the same time He made to copper plates that was a perfect mate and interlocked together used them for 15 years than sold the truck. Work really good can make a drawling if you want. You will need a Lathe to make this kind where the kind Dave has would be easyer to make. And I'm sure works well.
    Sep 2008
    Saskatoon, Sask, Canada
    94
    Quote Originally Posted by Vernon View Post
    I would love to see a drawing or picture.
    Hobart Mega Arc 5040DD (with built in air compressor)
    MM Passport Plus with Q-gun
    O/A
    sold MM 251
    There are only 2 tools needed in a tool box. 1) Duct tape to fix any thing that moves that isn't supposed to. 2) WD40 to fix anything that doesn't move but should.
    1,920
    Quote Originally Posted by RoughneckDave View Post
    heres a set i made
    dave
    You say there not hot but it looks like you have a lug on the inside with a connector on the outside. Is this isolated from the reel somehow? The diameter of the pipe looks small, does the cable wind up o/k?
    Kamloops BC Canada
    82
    Thumbs up welding reels
    check the pictures I have of my rig under the thread. Hobart/ Miller at the lake. and you can see my reels, they are made from Alum. horseshoes. get a lot of comments about them. they are not live. have four. two for welding leads one for extension cord. and the other one I use for 200 feet of 10/3 cable so as to plug in my mig and tig welders for 220 power off of my welder. diverdown
    2001 Dodge Ram welding truck. Hobart champion 10.000, miller Diversion 165. miller 180 autoset with spoolgun. SIP plasma cutter. Airless plastic welder.1996 28 foot bayliner for hauling dive and welding equipment
    Apr 2010
    Bronson, Fl
    168
    Hey vern, I too would like to see a drawing of the set up you used. I am thinking of making a set for my shop and need some ideas to ponder on. Thanks!!!
    Bob
    May 2009
    The Colorado Gas Patch
    185
    Here's what I did for the syncro 250 set-up..
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Torchmate 2x2 CNC Plasma
    It's Miller Time - Get Back To Work!
    Apr 2010
    oklahoma city, ok
    18
    I built some about 10yrs ago. One is hot, they hold 300 feet of lead. I will post pictures tomorrow if you are interested.
    Apr 2010
    oklahoma city, ok
    18
    Here are the reels I made. They have brass bushings. Nothing fancy though.
