    May 2008
    Troy, MI
    361
    Default Lawn Tractor Frame Repair 1
    My latest project was welding up the frame on my friendís lawn tractor. I believe that the tractor was damaged when it was used to plow snow by a past owner. It currently will be used only with the lawn mower deck. We added angle iron on the corner to beef up the frame. To make it really rigid I plug welded it in addition to the fillet welds on the edges of the angle iron.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    361
    Default Lawn Tractor Frame Repair 2
    Final Pictures:
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Sep 2006
    Abilene, Texas
    639
    That's a first class job Don. Your friend should appreciate what you did.
    Jim
    May 2008
    Troy, MI
    361
    Thank you.
    My friend did appreciate it. He helps me with my jobs all the time. Our latest project is installing a new hydronic furnace in my basement. The sections of the old one, as you can see in the picture, weighed 1100 lbs. We got $94 for the scrap. The new one is the size of a dehumidifier. It isn't really a welding project but soldering is close.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Nice work.
