a while ago i picked up one of these gizmos
http://cgi.ebay.com/Switchable-Magne...QQcmdZViewItem
its a switchable magentic ground clamp.. i like it alot and its nice to get the grounding point closer to the point of weld for my MM210.. i was just curious if you guys think that the magnetic field that it has would screw up my welding at all..
Thread: magnetic ground
12-07-2007, 07:42 PM #1
- Sep 2006
- 72
magnetic ground
12-07-2007, 09:30 PM #2
- Oct 2007
- Cave Creek Az
- 794
While in the company weld shop one of the guys was using one of those on a big (BIIIIIG) header. On one of the last welds it put an arc burn in the middle of the pipe. Last I saw it, it was flying out the door.
12-08-2007, 02:27 PM #3
I have read . . .
I have "read" that a magnet anywhere near a MIG puddle will pull the puddle and deform your bead . . .
12-08-2007, 02:33 PM #4
Try tigging next to a strong magnet sometime. Doesn't work so well.
Some objects and projects are more suited for a magnetic ground than others. If you were doing a fuel cell, for instance. You could slap the magnet on a side far away from your work area and not have to worry about the clamp disrupting your ability to set the box flat. Working on a welding table would resolve this, but sometimes that's not always possible.
I wouldn't throw away a standard ground clamp for a magnetic one, but I can see where it might be handy to have from time to time.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
12-08-2007, 02:50 PM #5
Ac/dc..??
Once a field has been magnetized, DC is worthless and you have to switch to AC (not a great alternative). I don't know if your tool would do this or not??
TacMigWe depend On:
Burco/Koco | Onan | BobCat
We belong to or support:
American Welding Society
The Welding Institute
Anderson & Co. LLC
Metal Crafters
12-08-2007, 06:55 PM #6
After using those red triangle magnetic squares, I dont have much time for magnets unless you use the real small ones to hold your work long enough to tack it. Unless its me, the two were never made to use together.
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
