    Apr 2006
    TAXACHUSSETTS
    1,481
    Default Asphalt Schuttle door
    This is a Schuttle,some may call it a coal shoot door.I fabbed for a dodge 1 ton dump.3"x3"x5/16"thk. angle framing,handle and linkage 2"x3/8"flat, door 10ga.plt.Made the tracks from 1/2"sq and some 1/2"x1/8" flat strip.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    HT/PWR-MAX1250 PLASMA
    Lodi, CA
    1,257
    Same thing, different name. In California, that's called a "ditch gate" .....
    Jul 2008
    Delhi, Ontario:
    1,969
    Looks good, does it do the job the way you intended ? Cool !!!!!!!!
    .......... Norm
    - Arcair- K 4000 CAC.
    - LN-25 Wire Feeder
    - Lincoln Power Mig 180C
    - Spoolgun.
    - DeWalt Chop Saw .
    Apr 2006
    TAXACHUSSETTS
    1,481
    Quote Originally Posted by nfinch86 View Post
    .......... Norm
    Of course Norm.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
