Results 11 to 20 of 21
Thread: fixing a dent
    Mar 2010
    245
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    Crete Illinois
    186
    Quote Originally Posted by SundownIII View Post
    Bondo.
    Real bodymen use lead.
    You're not using lead on that area of a new car........more warpage than you'll want to deal with....coming froma bodyman who uses lead.
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    Hypertherm Powermax 30
    Mar 2007
    Deltaville, VA
    2,239
    Uho,
    Yeah. If you haven't figured it out, I was pulling his leg a bit.
    Nothing wrong with bondo if used properly. I first used it in the 60's with a Corvette I had. Little hard to use lead on fiberglas.
    Problem with bondo is that so many people use it wrong. Use it as a "crutch" to get around poor bodywork.
    This new hi-strength steel used today, I'm sure, would throw me a curve. I was taught how to use a torch and wet rag to shrink metal by my uncle more years ago than I care to think about. I'm sure it wouldn't work with todays materials.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  4. #14
    Mar 2010
    245
    bumper bracket reinforcement technique
    Lockheed Martin
    USW local #3185
  5. #15
    Crete Illinois
    186
    Uho,
    It still works ..Just a little more temperamental than the older stuff......I did some lead work recently on a 70 nova hood that I welded a cowl scoop on.........lemme tell yuh the hood took the heat no problem,the aftermarket scoop on the other hand wanted to walk all over.....had to refine my method a wee bit but it worked out ok.. Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
  6. #16
    Mar 2010
    245
    when i did that 65 gto conv resto, i replaced the hood due to rust in the nose..
    i took my zip wheel and cut out the old 65 scoop section and sold it on ebay for 150.00 and trashed the rest of the hood.
    5-6 people wanted it too!
    just the scoop part with 2in of meat going around it.
    crazy, huh?
    Lockheed Martin
    USW local #3185
  7. #17
    Crete Illinois
    186
    That scoop means the difference between a Lemans hood and a gto hood.......both of which are getting harder to find clean rust free examples of. I'm a big fan of saving stuff like that myself.........that's why I've got a pole building filled to the gills with crap I'll probably never use or need.......till right after iI get rid of it lol Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
  8. #18
    Mar 2010
    245
    i always spray primer on bondo at the end of the day so water doesnt soak into it.
    i sanded that back off,, used a thin bondo to bondo the bondo and a powered guide coat,, again sanded off by hand.
    now its ready for the primer and ill blend the paints together on that panel, after that, i clear coat the entire panel.
    Lockheed Martin
    USW local #3185
  9. #19
    Mar 2010
    245
    epoxy primer
    Lockheed Martin
    USW local #3185
  10. #20
    Aug 2007
    arkansas
    781
    looks pretty good so far...
    welder_one
    www.sicfabrications.com
