    Near Great Smokies Ntl. Park
    60
    Post how much thicknes ALum.use Spoolmates?
    Wonder, will those MillerMatic DV12 w/ Spoolmate(#951067) or 212 w/ Spoolmate (#951068)or ,MillerMatic252 w/Spoolmate able weld on ALumunim 3003AL(1/16”thickness) and 6061-T6AL (1/4”thickness) plate to be weld?
    This is 6061-T6AL. 1/4" thickness.
    Wonder, how thickness those items could weld on 6061AL (1/4”thickness) plate?
    MillerMatic 211
    arkansas
    781
    you'll have a hard time with the .063 al, but you should be able to handle the 1/4 just fine. you'll have to pay attention to your duty cycles though. the 3003 will weld to the 6061 but use 5356 filler alloy. any more questions, just ask
    welder_one
    www.sicfabrications.com
    60
    Quote Originally Posted by welder_one View Post
    I am not familiar with 5356 Filler Alloy things.
    What is 5356 filler alloy? Look like Filler Rod and must using TIG Maxstar and Dynasty TIG?
    I looked at Goggles search relating to it. http://www.htpweld.com/products/tig_...etal/index.htm. that what you explain. Correct?
    Also I search at Miller Search and found>>>interesting :
    1)http://www.millerwelds.com/education...6+filler+alloy
    2)http://www.millerwelds.com/education...6+filler+alloy
    No Good on Millermatic 212 or 252 w/Spoolmates with Filler Rod. Correct?
    MillerMatic 211
    60
    Quote Originally Posted by Ls2cam View Post
    Just found out. I am getting better to understand what you(welder_one) mean. Good link:
    http://www.alcotec.com/us/en/educati...ller-alloy.cfm
    One more question about MillerMatci 212 or 252 not able using Filler Rod? Correct?
    MillerMatic 211
