Results 1 to 10 of 11
    Jan 2008
    So. Cal
    100
    Default Lowes Garden Cart
    Has anyone ever modifyed or re-built the steering linkage and rear axle on one of the Lowes garden cart?
    Fab Tech
    Sep 2006
    Abilene, Texas
    639
    41 views and no replies. I don't guess that anyone has. What do you plan on doing to the cart?
    Jim
    Jan 2008
    So. Cal
    100
    Well 106 views and still nothing. It might be a tough project I got myself into
    I’ll see what I can do
    Hope this project is not too big for me
    Fab Tech
    May 2010
    Central CA
    785
    If you are talking about the Ackermann theory. The inside tire has a smaller radius.
    I hope I spelled his name right.
    Bob
    Edit
    Thanks, PTsideshow I knew I butchered his name.
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Sep 2006
    316
    I guess you're talking about a four wheel steer wagon.
    I've built one for my mig when I wanted to run it over gravel. All I did was make an angle iron frame for the the bed. Then I made two pivoting axles, think of two front ends on a wagon. On one I attached the tongue. Then I attached a rod diagonally between the front and rear axles.
    The great thing about four wheel steer is you don't have to allow for tail swing or tail cut when making a corner. Properly made your wagon's rear wheel will follow in the exact path of the front one when making a turn.
    The downside of the one I built is when making a sharp turn the wagon can tip over if top heavy. But it was simple and easy to make so I did it that way knowing I had issues with tip over under some circumstances.
    Now if you're handy and can make your axles with king pins and tie rods, as on a go kart, golf cart, automobile, you can have a four wheel steer wagon that trails tricker'n than anything without the tip over issues.
    Jun 2008
    Mount Clemens,Mi
    350
    Don't know If you are talking about one of these
    Tractor supply garden dump cart, was thinking of what can be done for other uses with the style of frame steering. I have no use for an off road/gravel welding cart. But it could work if the center of gravity is lowered.
    All the bits and pieces laid out, I did a review of that style for another site. the steering part is upper right side in this photo the draw bar is attached by pivot to the center of the control arm to each wheel. As this cart can be used to tow behind a lawn/garden tractor. The handle can be turned around for a hitch pins trailer hitch
    This is the front section of the frame,Steering assembly before being attached
    If you are looking for what the steering looks like I can go out and snap a few pic's but right now it is filled with Fruit wood being transferred form its former home to its new short life as fuel for the son's smoker
    This is the small version carries less than the 1,000 pound version, the garden flat top carts at the garden centers around here all have the same type of steering set up.
    Quote Originally Posted by Bob Miller
    If you are talking about the Acrman theory. The inside tire has a smaller radius.
    I think you may be referring to Ackermann type
    Here is the google link there are a number of illustrations that are available
    glen, If your not on the edge, your wasting space
    Apr 2007
    Colorado
    35
    Default Intense!
    I love these posts/subjects that challenge all your engineering and welding skills. If I recall, thinking back to my erector set days, screw 'A' goes into slot 'J' and tighten gently. Don't overtighten this bolt as it will have to be removed and another support placed on the screw at a later time.
    Be sure to have sufficient air in your tires. Never leave your wagon behind your father's car. (...how many times have I told you to put your toys away when your done with them.)
    Jun 2008
    Mount Clemens,Mi
    350
    Quote Originally Posted by jerems View Post
    Never leave your wagon behind your car (father's) .
    Is the correct quote! he 's 85
    Jan 2008
    So. Cal
    100
    My neighbor wanted to use mine but I said No________way. He bought the yellow one Friday; he was moving block Saturday for his wall and the front wheel hub blew out and the whole thing collapsed, way too funny, he threw a tantrum. So I thought about beefing up mine befor it happens to me .
    http://www.lowes.com/SearchCatalogDi...=garden+cart+#
    Fab Tech
    Crete Illinois
    186
    I've got a different version of that same cart bought about7 years ago.......I don't think realistically you should have a problem with it.......I was using it haul logs from a gigantic tree we cut downmore than a 1000lbs at a time......thank god for ratchet straps.....and using my rider to haul it around.........never a problem with it........still have it lengthened to 8 foot long now.its my party tent permanent hauler......definitely one of the better purchases I've made.Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    Hypertherm Powermax 30
