Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
  1. #31
    Nov 2006
    Lake of the Ozarks MO
    3,594
    Quote Originally Posted by stugots View Post
    this is just silly,,, green works great, the trick to using green,,, is knowing how to weld....
    and like i said a few posts up,, it still has its place in the welding world today, or at least in my world.
    pure produces some of the nicest, roundest stacked dimes
    not this "V" pointed inverter crap,,, LOL
    like this
    not this
    So do you honestly believe, with everyone in the world wanting to tig weld aluminum, mainly because of the stacked dime look, that everyone would also be buying inverters that gave a "v" shape instead???
    It is the prep that you do on the tungsten that gives you your shape. If you make a ball on the end of your lanthanated the same dimension as on your pure then the puddle will be the same shape. Tungsten isn't magic.
    The alloys in tungsten are blended to handle the effects of electricity and it's polarity in varying amperages. The puddle is effected by the shape you grind it.
    I can set both of my Dynasties on sine wave and adjust the frequency and balance to make a wetter puddle than your "old school" (not!!) Syncrowave EVER could. (Give 40hz a try sometime)
    If you want to be defiant that is fine...I can even admire that at times. But don't let it pull the wool over your eyes to the point that you are uninformed about what you believe. It makes you sound like you are less expirienced than you are.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
  2. #32
    Nov 2006
    canada
    66
    Well said Fusion King The rebuttal will be here soon as he won't let go LOL
    Ronnie
  3. #33
    Mar 2010
    245
    to do what you said,,, it would make the fancy machine act more like a non inverter setup running a pure tungsten.
    thereby making the buying of an inverter over a transformer type just a pointless expenditure of ones funding.
    im a welding jedi, i become one with the puddle, i have no time for pressing buttons, grinding fancy tungstens or reading howto turn on your dynasty stickys !!
    LOL
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
  4. #34
    Mar 2007
    Deltaville, VA
    2,239
    FK,
    Well said.
    I don't think his comments "make him appear less experienced than he is".
    I think he's just a hack, that doesn't know any better, but has got a big mouth anyway.
    His comments just reconfirm what many of us already knew.
    Rebuttal in 3,2,1....
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
  5. #35
    Nov 2006
    3,594
    LOL
    Once again you miss the point
    The inverter can reproduce the arc/puddle of a transformer whenever you wish.
    And you can modify it whenever you need it. You can use it to ENHANCE your style and ability. While using 1/2 the energy!! And way less than 1/2 the weight and space taken up.
    Try running a syncrowave on 120v.
    If you know what a pure transformer arc is like and when it is good to have, then you can simply dial it in....or even make an improvement over that, in the same direction.
    BTW...if you are setting here and typing responses, then you have plenty of time to set a hobby welder in your home shop. Let's keep it real here.
    The day is pretty much here that if you was to apply for a job welding non-ferrous and was competing for a position against an equally talented weldor...the man who most understands the modern inverter technology and how to put it to the best use....will be the man who continually gets the nod.
    Miller WC-115-A
    Miller Spectrum 300
  6. #36
    Mar 2010
    245
    thats not true at all, inverters in real world fabrication shops are as common as hen's teeth.
    just wondering
    perhaps you or someone else could explain to me how this "fushigi" ba!! type thing on tv works?
    it cost 19.99 and seems to defy gravity,, im half temped to buy one and cut it in half just to find out.
    "Fushigi Magic Gravity BaII"
    Lockheed Martin
    USW local #3185
  7. #37
    Nov 2006
    3,594
    Maybe in the ones that have not upgraded in the last 10 years.
    Miller WC-115-A
    Miller Spectrum 300
  8. #38
    Mar 2007
    Deltaville, VA
    2,239
    I suspect Stugots wouldn't know a "real world fabrication shop" if he was standing in the middle of one.
    Based on the comments I've seen, he doesn't even know what the machine he has is capable of.
    Dynasty 200 DX
    Hobart HH187
    Dialarc 250 AC/DC
  9. #39
    Mar 2010
    245
    and what comments would those be to bring you to that conclusion?
    its been my experience, that people who act in such a way as you are doing,,, may know a great deal about the text book aspects of a trade, they own a bunch of fancy tools and such, but when it comes to preforming the actual hands on work aspect, the results are always less than stellar and or take three times as long to preform....
    i compounded the above view with the fact that you own or owned a corvette,,, and this only leads me to believe that im in fact correct in my original assumption.
    Lockheed Martin
    USW local #3185
  10. #40
    Nov 2006
    3,594
    Man I wish I had a Vette. As for real world.....all my friends KNOW I wake up in a different world everyday!!!
    Miller WC-115-A
    Miller Spectrum 300
