Why is it that when I finish a pass close to an edge, peddle down and it looks like gases bubbles in the weld escaping. Any suggestion on how to prevent this?
jim
Thread: End of a TIG Weld Pass Puddle
12-05-2007, 08:34 PM #1
- Sep 2005
- 72
12-05-2007, 10:39 PM #2
- Feb 2007
- Olive Branch Ms
- 129
Are you talking about a really short distance at the end of your pass? I had a problem for a while when I was at the end of my tig passes that sounds somewhat similar to yours. I figured out that if I slowly rolled back my current right at the end and let the gas stay on it for several seconds after the arc was stopped I stopped seeing the bubbles. I don't know if this will apply to your situation but hopefully it may help. Adam
Webb's Welding and Repair LLC
MM210 w/a 3035 spoolgun
Spectrum 625
Trialbazer 302 w/HF
http://webbsweldingandrepair.com/home
12-06-2007, 11:19 AM #3
Same here.
If i step off the heat at the end of the weld, the puddle will shrink back a bit and there will be a small pit in the very center of the bead.
So back off the heat just enough to solidify the bead, and then heat it back up a bit and back up a little. This seem to leave a fairly decent finish to the bead.
What picks my A_ _ is when the very end of the work "falls off" or melts becuase i didnt back off the heat. Too busy thinkin 'bout girls or sumthin....Will it weld? I loooove electricity!
Miller 251/30A spool
Syncro200
Spectrum 625
O/A
Precix 5x10 CNC Router12"Z
Standard modern lathe
horizontal 7x12 bandsaw
Roland XC540 PRO III
54" laminator
little dog
12-06-2007, 04:26 PM #4
- Sep 2005
- 72
Tonight I'm going to try welding in from both edges and then filling in the middle. My part is only 1/2" wide and after milling off the excess I really need the 1/2"
Thanks for the help, Looking for a mentor in Houston, TX N.W. Side to show me some tricks.
jim
