I used an abrasive disc on my grinder to get the mill scale off the stainless and rough up the copper. It cleaned off the burrs from the edges as well. The clear spray paint also takes a little bit of the edge off. I didn't need a high polish; plus, you would scratch the polish badly trying to weave the strips and getting those cleaned up after weaving is really difficult. I ground down the tack welds so the inserts would fit in the rabbits of the wood.
Also, I found that the 4 1/2" abrasive discs from Harbor Freight for about $5 last a good bit longer and don't heat up and leave residue quite as bad as the 4 1/2" Gator Grip discs from Lowe's that cost about $11.
Results 11 to 11 of 11
Thread: Bed Project
06-15-2010, 06:21 AM #11
- Apr 2010
- Jackson, MS
- 74
MillerMatic 252
Spoolmate 200
Diversion 165
Spectrum 625 X-Treme
Dayton 6" Miter Band Saw
Delta Drill Press
Bosch 10" Table Saw
Jet 5 Ton Chain Hoist
Radnor O/A
