Results 1 to 5 of 5
    Nov 2009
    Central Arkansas
    46
    Default Stair Rail Project
    Here are a few pictures of a recently complete railing project. The curve was the hardest part. Home owner is very happy with it.
    Rick
    Trying to succeed, Learning by failing
    HH210 (Merry Christmas to Me)
    HH 140
    Hyper Therm Powermax 600
    Hobart Stickmate AC/DC
    Forge
    Victor & Harris Oxy/Act
    HydMech 225 cold saw
    several grinders
    Rigid Chop Saw
    4x6 band saw
    Never enough clamps
    Aug 2007
    arkansas
    781
    nice work, good lines, and i bet that curve was a little difficult. nice job.
    welder_one
    www.sicfabrications.com
    Feb 2010
    Houston, Tx.
    378
    I got all excited when I saw Brewer in the pic descriptions, then ---
    All joking aside that is a fine looking job, even without the fermentation tanks in the background.
    Oct 2009
    305
    very nice railing.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Mar 2009
    NY
    103
    Hi nice job, one thing I might suggest is to not be so stringent on spacing dimensions on a custom stair. You must keep to code spacing or smaller which gives the opportunity to adjust spacing of the Balusters and Newels to give the illusion of consistent spacing removing the glitch in rhythm you have at thous locations with adjustment in spacing.
