Results 1 to 8 of 8
    Dec 2009
    Streamwood, IL
    87
    Default DIY Step Stool Plans?
    I'm needing some aluminum welding practice, and I thought that making
    a step stool would be a "nice to have around the shop" project.
    Yeah, I know that I could just buy one.... but i've got many pieces of
    3/8" thick plate, and at least one TIG welder around here.
    Does anyone have an example of one, which they made, that they'd be
    willing to share?
    _kevin
    Syncrowave 250 Analogue
    Maxstar 200SD
    Maxtron 450
    IntelliTIG 40
    S64M Wirefeeder
    Non-Blue:
    Hypertherm PowerMax 1000G3
    Lincoln Precision Tig 275
    Lincoln WeldPak 155
    Oct 2009
    306
    I'm making a set of stairs out of 1.25" aluminum radiused corner square tube. I'll post some pics when I get it started.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2008
    Arizona
    812
    I always try to avoid stepping on any stools!
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Feb 2010
    Houston, Tx.
    378
    I don't mind being waist deep, i just don't like it when they make me stand on my head!
    northern NJ
    1,884
    Flip a milk crate upside down then copy it.
    MM250
    RCCS-14
    Nov 2009
    Regina Sask. Canada
    15
    Default step stool
    Make the base larger than the top for safety, won't tip when you reach too far
    Oct 2006
    Cleveland, Ohio
    38
    How about making a box that's 1x1.5x2 ? Maybe cut hand hold ovals in the center of the sides.
    Stand it on whatever side for the required height.
    We had a few boxes made like this out of plywood in a shop I used to work at.
    Do you think Aluminum would slip on the grit on the floor?
    May 2009
    Central North Carolina
    148
    You could do a Google search for "step stool plans". You will find many wooden step stools of all kinds to build. All you will have to do is translate the plans into thinner aluminum stock. The proportions and part shapes will remain the same.
    Here's a link to a simple one /www.woodworkingcorner.com/stool.php
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
