I'm needing some aluminum welding practice, and I thought that making
a step stool would be a "nice to have around the shop" project.
Yeah, I know that I could just buy one.... but i've got many pieces of
3/8" thick plate, and at least one TIG welder around here.
Does anyone have an example of one, which they made, that they'd be
willing to share?
Results 1 to 8 of 8
Thread: DIY Step Stool Plans?
06-10-2010, 03:01 PM #1
_kevin
Syncrowave 250 Analogue
Maxstar 200SD
Maxtron 450
IntelliTIG 40
S64M Wirefeeder
Non-Blue:
Hypertherm PowerMax 1000G3
Lincoln Precision Tig 275
Lincoln WeldPak 155
06-10-2010, 03:17 PM #2
- Oct 2009
- 257
I'm making a set of stairs out of 1.25" aluminum radiused corner square tube. I'll post some pics when I get it started.
and wp2025 weldcraft torch
Miller 125c plasma cutter
06-10-2010, 06:32 PM #3
I always try to avoid stepping on any stools!
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
06-10-2010, 07:46 PM #4
- Feb 2010
- Houston, Tx.
- 378
I don't mind being waist deep, i just don't like it when they make me stand on my head!
06-10-2010, 08:27 PM #5
Flip a milk crate upside down then copy it.
06-11-2010, 08:12 AM #6
- Nov 2009
- Regina Sask. Canada
- 15
step stool
Make the base larger than the top for safety, won't tip when you reach too far
06-11-2010, 04:05 PM #7
- Oct 2006
- Cleveland, Ohio
- 38
How about making a box that's 1x1.5x2 ? Maybe cut hand hold ovals in the center of the sides.
Stand it on whatever side for the required height.
We had a few boxes made like this out of plywood in a shop I used to work at.
Do you think Aluminum would slip on the grit on the floor?
06-12-2010, 04:31 AM #8
- May 2009
- Central North Carolina
- 133
You could do a Google search for "step stool plans". You will find many wooden step stools of all kinds to build. All you will have to do is translate the plans into thinner aluminum stock. The proportions and part shapes will remain the same.
Here's a link to a simple one /www.woodworkingcorner.com/stool.php
Charley______________________________
Miller MM252
Miller Bobcat 225NT
2 O/A torch sets
Milwaukee 8" Dry Cut Saw
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Wallace 5 Ton Gantry
Too many hand tools
