    Jun 2010
    3
    Default cp-300 welder(const voltage power source) 460v vs 480v
    we have aquired a cp-300 mig, serial JK614003, stock 902931 , for our mech maint shop. The spec plate indicates 200/230/460 volts 3 phase of course. Our electrical panel is 480 v 3 phase. Will this welder work powered from a 480v panel tapped for 460 v. ? appreciate advice.
    May 2010
    Central CA
    788
    Default Should
    Some people call the voltage: 110,115, or 120, then 220,230,240 which gives rise to 440,460, and 480.
    http://www.millerwelds.com/om/o235r_mil.pdf
    On page 8 show the jumper posititons.
    Good Luck
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Jun 2010
    3
    thanks miller, i'll check the actual voltage, I checked the jumpers and they are on the 460 taps. I'll get back later. thanks again.
    Mar 2010
    Ceres, California
    358
    You will not have a problem. I do believe It is + or - 10%.
    460 volts plus 46 volts is 502 volts. max.
    I have seen these unit run all day long on 480 to 490 volts.
    Where you will have a problem is with a 575 volt machine run on 480.
    the contactor coils will short out from to much current. caused by low voltage.
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
    Jun 2010
    3
    I powered up our welder last night , and it cooks just fine. Thanks guys for the input. Jim
