Results 1 to 10 of 11
    Jun 2010
    3
    Default Miller CP 300 Problem
    Hello, I have been working on a cp300 that I bought to use in my shop, When I got the welder, the control relay cr1 was bad and it would'nt do anything but run the fan. I replaced cr1 and the welder would weld, but after a short period (1/3 of a 1/8" 7018 ) it will just lose the arc. in a moment it will weld again, well arc again anyway, but it is an erratic arc, acting cold one second and hot the next. When I got the welder the jumper links were set to 480v I set them to 230 and have rechecked their position to make sure they were set correctly. The power in the shop measures 240 leg to leg, 120 to ground on two phases and 235 or so to ground on one phase. I have the wild leg connected to L2. I tried jumping the thermostat to make sure it was not opening, and it made no difference. I checked the contacts and while they didn't look new they didn't look bad. I have cleaned the cable connections. I put a meter from the positive to work legs and the voltage is erratic. The surface of the coils where the brushes meet them look ok and are not pitted. If anyone has been there done this I would appreiacte any help youi could offer. I would like to fix this old welder and also use it with a s-22a feeder. thanks -dave
    May 2010
    Central CA
    785
    Default CV only
    Correct me if I'm wrong, but isn't CP-300 a CV only machine.
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Jun 2010
    3
    Bob I'm new to working on a welder , I couldn't correct you , The cp 300 I have is a constant voltage machine with the 14 pin connection I'm sure i've just shown my ignorance again but can you elaborate for a novice..
    May 2010
    Central CA
    785
    Default 3 Phase
    Both of my CPs are 3 phase only. If you have 3 phase hook up the 22A and start welding with wire. On those machines it does not matter how you put the legs.
    Just make sure you have 3 hot legs.
    Good Luck
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Aug 2008
    Orange, TX
    1,216
    Quote Originally Posted by Bob Miller View Post
    Sure is.
    Dave,
    As Bob was implying, the CP300 is a Constant Voltage (CV) power supply designed and meant for MIG welding (that S-22A wire feeder) and not stick or TIG.
    That said, double check those brushes to make sure they're all free in their holders. They have a habit of sticking due to rusty holders and/or dust build-up and loosing contact with the transformer windings.
    If I understood you correctly you already checked the mechanical contactor to make sure its contacts were clean which would be my next spot to look.
    And then on to the diodes in the weld output rectifier but one or more failed diodes usually means a short (tripping breakers) or low/no output rather than fluctuating but anything is possible.
    What is the unit SN?
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Aug 2008
    Orange, TX
    1,216
    I'm with Bob. Hook it up to the S-22A (correct process device) and go from there.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    May 2010
    Central CA
    785
    For 7018 you need a CC (constant current). Your CP (constant potential) is constant voltage (CV) for wire only. And they only run on 3 phase power.
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
    Jun 2010
    3
    Thanks, Its nice to confirm that I'm an idiot. as have been trying to stick weld off this machine, the serial number is KF765659 Thanks for the education I will hook up the wire feeder and see how it goes. with my hat over my face, I say thanks again!
    Aug 2008
    Orange, TX
    1,216
    Don't sweat it Dave. Just part of the learning curve.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    May 2010
    Central CA
    785
    Dave,
    Don't leave us hanging, tell us how it goes. We all want to hear a success story.
    Bob
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    Millermatic 211
    Passport Plus
    SA-200 Red Face '69
    SA-200 Red Face '66
