Results 1 to 10 of 14
    Jan 2007
    Delmont, PA
    291
    Default Rolls Royce Manifold Repair....
    Hey guys,
    Attached are pics of the 2nd Rolls Royce exhaust manifold I repaired using the "Cold Welding Cast Iron With MIG" process I have used with complete success.
    This manifold was cracked thru the inside flange & the manifold had a severe warpage. After wire wheeling clean, I beveled each side of the crack & extended a bit past the end of the crack. The weld parameters were: .030/309L wire(.01carbon content), 98/2(AR/CO2) @ 18cfh, 90-100A. I tacked each end of the crack & peaned to start. Then I ran a 1/2" bead(pull not push), peaning immediately after welding to relieve the weld. The casting got only warm to the touch & this is the secret to eliminating the dreaded "tinkle". After 15 min. or so back to room temp., I did the 2nd weld on the opposite side, peaning again. I repeated the process till the entire crack was filled nicely.
    When I was finished, I took the manifold to the automotive machine shop that does all the machining on the race engines my brother builds. Their work is superb & they have a very extensive machining operation. They surface ground the manifold back to true flatness.
    Here's the pics....(9).... gonna need (2) posts to get them on, so give me a couple xtra minutes. Thanks....
    Denny
    * Complete welding, machine, & fab shop *
    * Mobile unit *
    * Finally retired *
    ____________________________________________
    * A man's word is his honor..... without honor, there is nothing. *
    * Words are like bullets..... once they leave your muzzle, you cannot get them back. *
    * I have no reservation to kill nor hesitation to die for the U.S. Constitution & the American Flag. *
    * Age is a state of mind..... at my age, you cannot fathom what is in my mind. *
    Jan 2007
    Delmont, PA
    291
    Here's the 2nd group:
    * Mobile unit *
    * Finally retired *
    Dec 2005
    wisconsin
    830
    Interesting repair,
    Must be just the pictures, but I swear it looks cracked at the toe of the weld in places. I guess the proof will be in how well it holds up over the next years. I have personally never seen much luck with arc welding cast iron, I guess others have though. Seems I always had better luck torch welding castings, let us know how it holds up!
    -Aaron
    Miller Dynasty 300DX
    Miller Dynasty 200DX
    Miller Spectrum 375 extreme
    Miller Millermatic Passport
    Miller Spot Welder
    Motor-Guard stud welder
    Feb 2010
    Houston, Tx.
    378
    I've never migged cast iron, but I've had good luck stick welding it. I use Ni-55 or Ni-99 depending on the situation. You have the right idea; You either weld it cold or weld it hot. No changing horses in mid stream. I have welded it both ways and still prefer a pre and post heat especially on smaller pieces.
    You sure better not be in any hurry with this work, especially with the no-preheat method using Ni-Rod (SMAW), which was the way I was taught: run 1/4" of bead at a time and GO AWAY until it's cool enough to hold your hand against it. My first project was the exhaust manifold for my '66 Econoline. That repair lasted at least 25 years, and never leaked . . . despite the fact that the weld bead gradually pealed itself away at the edges, eventually looking like I had laid a length of cast iron clothesline in the bottom of a V-groove! Anyway, having become pretty confident about this system, I showed another guy how it was done, but I got in a little too much of a hurry, and generated some new cracks, very embarrassing!
    I've got some new rod from All-State that is suppposed to be used with a 600F preheat (which always did seem to me to be the way to minimize welding stresses), but have not tried it.
    While old exhaust manifolds with a lot of miles on them probably have had some of the as-cast locked-in stresses relieved by the years of vibration and thermo-cycling, I wonder if the metal hasn't had some of its mechanical properties "burned out" . . . ??
    Dec 2005
    wisconsin
    830
    Quote Originally Posted by seattle smitty View Post
    Well it does atually lose carbon over the years, especially exhaust parts it seems. Another thing to remember is that along with age, casting material has changed over the years. So when someone has trouble working on a 1918 Mekur exhaust manifold, is it age, or material? I rarely work on anything less than 50 years old, so I guess im used to dealing with older materials, and age in general. That being said my experience with electric weld failures is also on that age of parts. By far I have the best luck with O/A welding of castings, yes its a bit slower, and hot work, but the result is beautiful. The welds really dont have a bead shape, they really just disappear, and the weld and base metal is so soft when done a file cuts it like butter. I have done everything from exhaust manifild cracks, to building up replacement cooling fins on a 1908 harley with the process, and done right a repair is undetetable as its just cast iron, base and filler.
    Miller Spot Welder
    Right, gas welding is better. More fun, too, because so many people are surprised that you can do it that way, and even more that it is still the best way.
    Oct 2009
    254
    Still end up with expansion and contraction of the cast material. It expands when heated and is held from moving by the rest of the cast iron around the welded area and has no where to go so it thickens the material and than cools and contracts which pulls on the welded area and then you get cracks. The only way to fix a crack in the middle of a cast iron part is to drill and pin it.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2005
    wisconsin
    830
    Quote Originally Posted by jrscgsr View Post
    Yes, which is why its pre-heated. Expand as one, shrink as one. As for pinning being the only method, nope. Plenty of production castings are welded, in production.
    Miller Spot Welder
    Apr 2009
    27
    Smile
    I don't understand why some people insist that cast iron can't be welded without it cracking.
    I can't count the number of cracked engine blocks, cylinder heads, intake manifolds, exhaust manifolds, etc. i've welded over the last 25 years and not one of them has recracked or leaked.
    So it's either not as tricky as some would like you to believe or I am the luckiest man on the planet.
    Miller Dynasty 200DX TIG
    Miller Coolmate 3
    Miller LMSW-52 Spotwelder - (Still Going Strong )
    Lincoln Sp-175 Plus MIG
    Miller Digital Elite Helmet
    Miller Elite Helmet
    Speedglas 9100xx w/ADFLO Helmet
