If you have (access to) a lathe, this is great.
http://www.postdiluvian.org/~mason/m...e-fab/notcher/
I just saw this the other day and I'm definately going to set myself up for this
Results 21 to 30 of 83
Thread: pipe fence question
08-05-2008, 11:15 AM #21
Member
- Jan 2008
- 87
Millermatic 180 Auto Set
08-05-2008, 12:04 PM #22
The chopsaw method works great with a portaband also.
08-05-2008, 04:22 PM #23
- Dec 2007
- Oklahoma
- 641
You are building a fence, not the space shuttle. Learn to cut the saddles with a torch, with or without a pattern. By the end of the first acre you will be cutting saddles in no time and thinking what was so hard about this.
Remember, your fit-up does not have to be perfect. Yes, the better the fit-up, the easier the welding. But 100% perfection is not critical on the saddles.
Griff
08-05-2008, 06:09 PM #24
- Apr 2008
- 5
A company called Heck Industries makes a manual pipe notcher it costs about 500.00 and will do 1.2 & 2 inch pipe. use alot instead of our abrasive belt notcher made by Linder Industries unfortunatly belts cost 30.00 each and use only for sloped rails.
08-11-2008, 09:44 PM #25
Member
- May 2005
- 40
The cheapest and easiest method is to get one of those Harbor Freight drill attachments and buy the appropriate size hole saw. The hole saw will cut a relatively clean notch and it will fit good enough. I use this method to make chain link fence panels and gates for kennels using 1 3/8 top rail.
MM251
Synchrowave 200
PowerMax380
Century 155GS
Big Window Elite
Run silent, run deep
08-11-2008, 10:13 PM #26
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
08-12-2008, 01:19 AM #27
I bet it would turn out better than a china homie depot sch 40 one...
The lathe notching I've seen done used an end mill chucked in the lathe rather than a hole saw. I've never tried either method on my lathe.
I only do hole saws on pipe when the radius is important and the wall thickness makes for a difficult bevel with the cutoff wheel (small diameter AL heavy wall tube to a large diameter tube radius and being tigged). Otherwise, it's so much faster to just knock the corners out of the tube and get to welding. Like has been said, once you do a half dozen or so, it becomes second nature.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
08-15-2008, 02:30 PM #28
I have built pipe and sucker rod fence part time for years and as people have said.......it aint no one day affair. I bought a couple of collars from the welding supply. one is for 2 7/8 pipe and one is for 2 3/8 pipe. one end is round so you can close it around the pipe and cut it off square and the other end has saddles on each side so you can mark out the saddle you need for the top rail. once you mark the saddle its easy to see where you are suppose to cut. drill stem is often rusty and has had some substance in it that causes the torch to pop and slag to run. i usually piont my torch down inside the pipe for a few seconds before cutting to try and burn off some of the stuff inside. good luck..
Millermatic 175
Miller 375 Extreme Plasma
Cobra Gas Torch
Bosch 14 Chopsaw
08-15-2008, 05:15 PM #29
Member
- Nov 2005
- 86
Pipe Fencing
Welding Supply Stores Sell Lay Out Jig For Different Size Pipe And Also For 90 45 Degrees Check It Out Small Tip Would Help Also Aim The Tip Away From The Piece You Are Using The Slag Will Stick To Drop
08-18-2008, 07:26 AM #30
Member
- Feb 2007
- Springfield, MO
- 35
Hello Bushman!
I cannot STRESS enough that you must try the chop saw method that Fusion King suggested before attempting anything else! It works slick!!! even though I thought I used a different angle, but I'm sure his right, because it's been a few years since my project where I utilized this method. For some reason I thought I used 35 degree's (????), but regardless, you'll fine tune the angle that works the best, especially with the wall thickness of your drill pipe. but trust me, if this method doesn't work for you, I'll come over help ya with your project & that should speak volumes! PM me if you're confused on what we're talking about. Good luck to you! Handirod
