I am having a problem with 6" X 1\2 " wall thickness pipe ,either cracking or snapping off completely just above the weld. These pipe are used on trench safety boxes, in which pipe crews put in yhe ground while laying pipe to keep the ground from caving in.These pipe are welded to the main frame of the trench box and are used to hold spreader bars in place.They are only 13" long,7" stick out of the box to pin the spreader bars to,I weld them to the main frame at the bottom of the pipe on the inside of the pipe,because you cannot get to the outside it is down inside the frame,at about midway up the pipe where it portrudes through the frame there is good solid 1\2" plate to weld to.I usually make one pass on the bottom and three passes at mid point with 7018 rods.These trench boxes take major abuse with big trackhoes pulling them along in the ground by the spreader bars. I am thinking cheap grade pipe? Itried to heat the pipe, maybe not enough preheat?
Results 1 to 3 of 3
Thread: pipe is cracking or breaking
12-03-2007, 06:23 AM #1
- Jan 2007
- 53
/22x45 concrete slab with 2 overhead cranes(trolley style with electric hoist, huge shade tree to weld under
33x33 enclosed shop when its to cold or windy outside
miller 210
miller 875 plasma
victor oxy/accet
unihydro 45ton ironworker
miller 180 tig
ole lincoln ac/dc buzzbox
milwaukee power tools
and everything in between
2007 trailblazer 302
Bailiegh 210 miter saw-2008
Beer Fridge
6000# cat forklift
36" port-a-cool fan
Dake G-75 Belt grinder
3035 Spoolgun
12-03-2007, 11:10 PM #2
Check the ATSM number on the pipe and get the procedure for it. You may just be off on the heat/pre or post and rods. I had some 6" do that once. With 6010's, all it took was one smack with a hammer to snap the whole weld. Weld it with a 400° preheat and 7018's and no issues. Sometimes this can be wierd stuff. Have you tried a different rod brand? I've seen that work, too.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
12-06-2007, 08:44 PM #3
- Aug 2007
- New Orleans, LA
- 161
Sounds like an alloy. Mild steel shouldn't be doing that. He is right about the procedure though. If it is used pipe and you can't get the astm off it try a preheat and post heat. I do that on cast iron posts with excellent results (as in none have ever cracked out or broken off at the weld) I heat the halves to dull red, make the weld and then reheat and let them cool out. I've had to do this in the past with steel pipe as well. It all depends on the type of pipe.
Westinghouse: 400+ amp AC
ThermalArc Handy wirefeeder
1 Harris, 3 Victor O/A rigs
Arcair gouger
