I want to fab a couple of those hitch mounted aluminum cooler/fishing rod racks. I have a 30A spoolgun. Any suggestions for the size/thickness of the tubing that is commonly used for these rigs? Approx. settings for the Millermatic 250/30A spoolgun would be helpful to this amateur. Thanks
__________________
Results 1 to 2 of 2
05-26-2010, 11:23 AM #1
- Nov 2006
- Richmond Virginia
- 5
Aluminum cooler rack and fishing rod rack help
Dr Gas
Millermate 250, Dynasty 200DX, 30A Spoolgun,oxy-acetylene, Pak-Master 38XL Plasma, Forgemaster forge, HF 110 anvil, Peddinghaus 275 anvil,
05-26-2010, 10:59 PM #2
- Jul 2006
- alaska
- 132
I thought about making one of those.
In lieu of a pipe bender I guess I would use some one inch square tube probably in the 1/8th inch thickness area, except the receiver part that goes into your hitch, that I would go 3/16 2 inch rounded square tube. Only an opinion, have fun
If I was to use my bender, then round tube in same configuration.
