Results 11 to 20 of 25
    Lodi, CA
    1,126
    All welding tables should be exactly 33 13/16" high.
    One of the nice things about metalworking, it's easy to make things longer or shorter as needed.
    Just build one, leaving enough room to cut some off the bottom of the legs if necessary, or add some. Or do like the guy previously said, make the legs adjustable.
    I agree with what SundownIII said. Like shoes, there is no perfect "one size fits all".
    Dec 2008
    Omaha, Nebraska USA
    44
    here is my table it is 35 inches tall it fits me I 'm 5'8".
    Nov 2009
    10
    I am 5' 10" tall. All my benches are 40 inches tall. This seems to be the perfect height for me and those I have made benches for in the past. You obviously can make the bench any height you wish. If you are going to stand at the bench like you said you are I am sure you will find that 90 cm is too low for most tasks and will be hard on your back. I also suggest you add some receivers as others have mentioned. Good luck.
    May 2010
    5
    thank you all for the replys
    I am considering again puting the saw on the table..
    i found out that 85 cm will be good for me (I'm 1.83 cm tall)
    do you have some pictures of table legs that can be shorten ?
    2,635
    Quote Originally Posted by nachche View Post
    You'll need a ladder to reach the table
    Lake of the Ozarks MO
    3,446
    WHOA!!! Are typing this on a standard size keyboard??
    Miller Bobcat 225 NT
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Miller Spoolmate 200
    Miller 225 Thunderbolt
    SPEEDGLAS 9100XX
    Default Table Height
    Of course it depends on the height of the work and the height of the operator.
    All of the tables in my plant are adjustable from about 28" to 38". Some legs are a tube inside a tube with a quick pin. Others have back to back channels with slots.
    Scott
    Fab Manager
    Welders360
    Cleveland, Ohio
    38
    I built my table 42" high. it's very comfortable standing / working if the projects aren't too big. However it puts the vise way to high. I'm thinking about receiver tubes on the legs to bring the vise lower.
    Jan 2009
    Ohio
    191
    Default Steel Bench
    The height of my bench is 35" or 88.9 cm The bench is 48" x 96" (121.92 x 243.84 cm) this works well for me at 6'4" (193.04 cm).I like it very much. Hope you find what works for you. I add a picture of my bench for you.
    May 2010
    Central CA
    711
    Default 40 3/4"
    My table is a piece 3/4"(19mm) plate 36"(91cm) in dia. I put 3-40"(101.6cm) legs on it.
    It's fine for little things, but any thing very tall I have to stand on a box.
    For tig welding I can sit on a bar stool and work the pedal.
    Mig welding it's fine. Stick welding, it's back on the box again.
    Before I would cut that one down, I'd build one a litte shorter, maybe 4"or 5"
    (10cm or 12.7cm) shorter.
    Bob
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    30A w/ WC-24
    HF-251D-1
    Select Lathe
    Exact Mill
    Spectrum 625 X-TREME
    Cutmaster 152
    Kalamazoo Band Saw
    SX60 Arc Station
    FX30 Arc Station
    8-Grinders
    5-Victor O/A
    4- Chop Saws
    2-Drill Presses
    Lincoln SA-200 Blue Tint Red Face
    Lincoln SA-200 Red Face
