    Jan 2010
    Calgary, Alberta
    197
    Default Welding Cart Build
    Hey guys, thought i'd post some pics of my cart i finally got around to doing!
    I built it from a rough idea i had in my head. I also did it fairly quickly in view of selling my welder with the cart since i have ideas of getting another welder from the same guy i got mine from originally.
    Anyway, i used 1.5"square tubing and some sheet metal. Nothing fancy, but it should do the job! I may add a section for tools, etc!
    Jan 2010
    Calgary, Alberta
    197
    Default More pics
    More pics of cart
    Jan 2010
    Calgary, Alberta
    197
    Last pic of cart!!!
    Jan 2010
    Calgary, Alberta
    197
    Sorry, you guys prolly aren't interested at something like this but now i've started, i might as well finish.
    Here is the last pics.
    Dec 2008
    Arizona
    812
    I'm jealous of your shop/work space. I work in a shanty.......
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Jul 2006
    alaska
    180
    Nice work.
    Nov 2009
    houston pa
    104
    Quote Originally Posted by nocheepgas View Post
    i was distracted by all that space too. not having space is more depressing than not having tools.
    Jan 2010
    Calgary, Alberta
    197
    Well to be honest with you, it isn't my space. I should have mentioned something in the first post... was going to but forgot. It is a brand new building my dads friend just built. They actually do drywall contract work, and are starting a new business which does pre fabricated bulkheads, walls, etc! The prefab business is where i was building the cart! Not mine unfortunately! Very kind of him to let me use it though! It has a 5 ton crane, and many other tools for fab work... plus the MM252 in the background.
    I'll be there one day! Hopefully
    Nov 2008
    Kansas City Metro
    387
    Sammy,
    The cart looks like it will serve you well. It sure beats the heck out of having to bend down to even look at the front of the machine. You will like it better having everything up on your new cart. And I am sure most everyone here will agree, with every day you age, every day you don't have to get down on the floor is appreciated.
    Nice work Sammy.
    Stickmate LX 235 AC / 160 DC.
    Clarke 180 EN Just in case
    Spectrum 375 X-Treme.
    Milwaukee 14" Chop Saw.
    4 x 6 Horizontal Band Saw.
    Projects and Misc Albums
