I just bought a MM350P with the xr alum pro gun last week. I have been running regular MIG mode due to the fact of not having time to play with the pulse. Well Saturday came and I had time. I got the pulse running nice. I used the book settings and dialed in the arc length and sharp arc settings.The book alse recomends a 90%argon/10Co2. I used my 75%argon/25%co2 tank with good results. I was thinking about getting a 90/10 tank on my next refill. Will there be any difference? I am welding steel by the way. I think I will be pulse mig welding everything now. It's really nice! What is the difference if any in the weld appearance or structual qualities with the 90/10?
At 1st I was not impressed with anything except the guns smooth wire delivery over 25ft. It was'nt untill I got the pulsed mig going that I was amazed. I can't wait until I can run alum.
Results 1 to 3 of 3
Thread: Pulse Mig Gas Question
12-02-2007, 05:46 PM #1
- Sep 2005
- Vernon Ct
- 117
12-02-2007, 06:02 PM #2
12-02-2007, 08:01 PM #3
- Mar 2007
- Deltaville, VA
- 2,241
MD Welding,
Nice setup you've got there. Glad to hear the pulse is working out for you.
Be careful, several posters (one of which I think was with Miller) have noted that the Push/Pull gun was designed for aluminum and a constant diet of steel wire will prematurely wear out the liner and that the liner for that setup is "VERY" expensive.
Don't have a push/pull myself but thought I'd throw that caution out there. Might be worth a call to Miller tech support.
