    A State of Confusion
    143
    Default Question lightning rod for a home
    Question How should a lightning rod for a home be made and what type of material would be best used for this project a wind vain type maybe ??
    Any picís thoughts or ideas would be appreciated.
    3,975
    Copper would be my choice from what i see on old barns around here. My dads barn has copper and a twisted copper wire about 1/8" x 1" coming to the ground. I see signs around here http://www.drboom.com don't know whats there but i see lots of signs...Bob
    Columbia SC
    165
    I would put a copper one foot high rod at the talest point on your structure, and run twisted stranded wire ( about the size of a pencil to handle the current) down to the closest point that I could find to the ground. The most important part is that YOU MUST have a good ground rod connected at the ground point. You want the lightning Arc to go to ground as fast as possible, and be dissapated all into that ground rod. I suspect that if you google lightning rods you will get some expert advice. To me, the most important part is the ground rod being well connected to the earth, other wise you are just attracting the lightning to your structure that you are trying to protect..
    Jim
    Mar 2010
    245
    this is one project that i myself would not even try,,, and im a complete nut.
    i once talked to an electrician about doing this type of thing myself,,, he laughed,, i believe that this is even separate from normal electricians know how, and is a highly specialized installation/certification/materials. after all,,, it involves god knows how much power,, coupled with the unpredictably of lightning.
    Anything you could do, I could do better.
    I can do anything better than you!
    Lockheed Martin
    Armco Steel, Baltimore
    USW local #3185
    May 2009
    Central North Carolina
    150
    Do a Google search for "Lightning Arresting Equipment". There are many sources for information, parts, and prices, but this is a very specialized field and it isn't a good idea to do it yourself.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    Sep 2008
    Toronto, CAN
    54
    Default Nfpa_780_2004
    Quote Originally Posted by CrazyHorse! View Post
    You can find some information in the following link:
    http://www.atmo.arizona.edu/students...A_780_2004.pdf
    Trailblazer 325 EFI
    SVI 300i cvcc
    Mig 4HD & Mig 2E wire feeders
    Ultra-Pulse 300i Pendant
    EAS-IV Electronic Arc Starter and Plumbing Box
    Powermax1000 G3 Series
    AC-225 Arc Welder
    143
    it's just for my own education of how no intentions of use just wondering how they are made and materials used.
    Jun 2008
    Mount Clemens,Mi
    350
    You want sweeping turns of the wire not sharp 90'bends. you also want a large dia of wire running from the spear to the ground rod's that are in the earth.
    And don't forget the glass indicator ball, so you know if you took a hit. The ball shatters, show you know when it gone you been struck.
    lightningrods.com
    lightningrodparts.com
    Here are two that you will find use full
    glen, If your not on the edge, your wasting space
    143
    Quote Originally Posted by PTsideshow View Post
    lightningrods.com
    Thanks great sites and good info!
    CH!
