Mabey you guys can help me with a problem im having with my plasma cutter. As the title states I have a Miller Spectrum 2050 and am having some problems.
The problem is that it will not start an arc when I pull the trigger anymore. The power light is on, the ready light is on. I have checked the air pressure, its good the only thing that i can think of is that mabey the stinger is bad. One other thing is that when i used to power it up the fan would come on for a second or two and the stinger would let pressure out which it does not do anymore.
Any help you could give would be great.
Results 1 to 3 of 3
05-20-2010, 02:22 AM #1
- May 2010
- 1
Troubleshooting Miller Spectrum 2050
05-20-2010, 09:55 AM #2
2050
After you have verified the pressure is where it should be with air flowing - you can force this condition by turning current to zero - check for 400 volts on each of the two large electrolytic capacitors in the top of the machine. Be careful, there are lethal voltages here. weldersales
05-20-2010, 01:32 PM #3
- Mar 2010
- Ceres, California
- 351
Check the trigger first and its connection in side the case.
Does the air flow in gas test?
Loosen the retaining cap on the torch 1/4 turn and see if it fires.
It maybe best to take it in. these are not easy machines to troubleshoot.Glenn 300 amp stick
Millermatic 35
L-tec plasma
