    Nov 2007
    19
    Default ok guys new weld. How does this one look
    I was using a lincoln weld pak, flux core wire. hows is this one? thanks
    http://i177.photobucket.com/albums/w...27/myweld2.jpg
    Nov 2007
    Jackson, MI
    57
    pretty good
    don't forget to fill in that crater
    Nov 2007
    19
    Thanks, yea i know. that was just a scrap piece that i only just welded alittle. ( didnt want to waste my wire)
    356
    looks fine
    mm210
    maxstar 150
    Nov 2007
    19
    anychace, just by looking does it look like it would pass a weld inspection at all?
    So. Cal
    335
    Default Not bad...But.....
    Quote Originally Posted by Shane View Post
    The weld looks O.K. but it's hard to tell if you got proper penetration. Also, why didn't you weld all the way around? To help better critique your welds, I along with several other members (I'm sure) would like to know the material, material thickness, machine, amps, filler and a cut-off side view to see your penetration. Otherwise all we are looking at is a bead. However, you bead looks good but remember, looks are deceiving especially in welding!
    Good luck and hope to see some more!
    TacMig
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
