    Nov 2007
    19
    Default how is this weld?
    This was me welding a piece of scrap with my lincoln weld pak flux core welder. what do you guys think of it? im still learning. thanks
    heres the link
    http://i177.photobucket.com/albums/w...r27/myweld.jpg
    Vancouver BC Canada
    605
    Hang on a sec, I need to go get my glasses....
    Do dee dooo..... umph.
    Oh its still fuzzy.
    Can you take another pic thats in focus?
    Miller 251/30A spool
    Syncro200
    Spectrum 625
    O/A
    Precix 5x10 CNC Router12"Z
    Standard modern lathe
    horizontal 7x12 bandsaw
    Roland XC540 PRO III
    54" laminator
    little dog
    Tennessee this week, Wyoming next week.
    49
    And put a coin or something next to the piece, to give us some scale.
    Cool welding scrap
    what position are you welding in? The only negative thing i can say is to slow your travel speed down a little. try practicing running stringers on flat plate 6 inches by 8 inches. cover the plate and lets see what that looks like. focus on uniform width and highth. Let's see some 1g,2g,and 3g positions. I believe your welds would be acceptable to an inspector, but remember this is an art.
    Try to make every weld better than the last one. Also it doesn't hurt to use that grinder and weld clean steel.
    Peace
